hyperterminal and lcd
nina
PostPosted: Tue Apr 21, 2009 3:05 pm     Reply with quote
Working just with hyperteminal (windows) the code below work perfectly, but when I tried to implement a push button and an lcd together with hyperterminal...it doesn't work. I mean, when I press push button nothing is sent to lcd.
If I take out the if using getc then if I press push button the message is displayed on the lcd.
Here is the code.
Thank you in advance.
#include <16F877.h>
#fuses HS, NOWDT,PUT,BROWNOUT,NOLVP
#use rs232(baud=9600, parity=N, xmit=PIN_C6,rcv=PIN_C7)//Configura serial
#include <flex_lcd420.c>
#define LED0 PIN_C0
#define LED1 PIN_C5
#define LED2 PIN_D2
#define botao PIN_E0
char dado;
main(){
   lcd_init();
   printf("Começando o Programa...");
   while(true){
if (input(botao)==1){
printf(lcd_putc,"Ligado");
         output_high(LED2);
if (input(botao)==0){
         output_low(LED2);
if (getchar()=='1'){
         printf("MENU 1!!!");
         output_high(LED1);
PostPosted: Tue Apr 21, 2009 3:26 pm     Reply with quote
Describe the external circuit for your push-button.
PostPosted: Tue Apr 21, 2009 3:32 pm     Reply with quote
The getchar function is blocking, it waits till a character is received on the serial port, leaving no time for processing the key inputs.
change:
to:
if (kbhit)
The kbhit function will test if a new character is waiting to be processed and only then calls the blocking getchar function.
nina
PostPosted: Tue Apr 21, 2009 3:52 pm     Reply with quote
ckielstra..it work perfectly...thank you very much for your help and cooperation..
nina
