Emulate i2c
DoppiaD
Emulate i2c
PostPosted: Tue Apr 21, 2009 6:16 am     Reply with quote
Hi , I'm working with pic12f683 that doesn't have I2c hardware. Are there any library that emulate i2c? I need it because I want to comunicate with a I2c eeprom.
Thank you at all Very Happy
Regards
David
PostPosted: Tue Apr 21, 2009 7:16 am     Reply with quote
The existing CCS I2C code, will automatically generate an 'emulation', if the hardware doesn't exist on the chip, or the pins you select. But _only_ for a master device.
So long as you don't need a slave (_very_ hard to do in software), just use the standard I2C functions.
DoppiaD
PostPosted: Tue Apr 21, 2009 9:40 am     Reply with quote
Thank you for the answer Very Happy
