SPI works with 1 slave but not with 5
topfuel@frognet.net
PostPosted: Wed Apr 15, 2009 7:06 pm     Reply with quote
I have an applicaiton that uses an SPI master 18F4685 and 5 SPI slaves 18F2523.
I have the master and 1 slave working. I add the other pcb to the spi bus, this board has the 4 other pics that are on the spi bus. Now when I restart the first slave no longer responds correctly.
I suspected that i had multiple pics selected on the spi bus . I have a simple 138 decoder to select the active slave pic.
The decoder seems to be working. I run the master code in debug and the slave select decoder is working correctly on slave 1-5.
I connected my scope to the sclk line and I can see the clock pulses but I notice that my project will not communicate while the scope is connected. Also I have no buffering between the mater pic and the 5 slaves. Should I?
Why does the scope kill my comm? The signal looks very clean on the scope, no rounded edges. Crystal is 16.384Mhz and spi is set to clk/64.
Tomorrow I will debug both master and slave at the same time to hopefully get a better idea what is going on.
Any suggestions?
Chris
PostPosted: Wed Apr 15, 2009 7:47 pm     Reply with quote
Buffering between master and slaves is normally not required. What is the wire length between master and slaves?
The scope can be loading the SCK line too much. Make sure to use an x10 probe.
Check out http://www.ccsinfo.com/forum/viewtopic.php?t=21650&start=10 this thread where a series resistor of 100 Ohm in the SCK line solved a similar problem.
topfuel@frognet.net
Thank You Mark at CCS
PostPosted: Sun Apr 19, 2009 7:04 pm     Reply with quote
I called Mark at CCS after several hours of troubleshooting.
Here is the culprit.
setup_spi(SPI_MASTER | SPI_L_TO_H | SPI_CLK_DIV_16 | SPI_XMIT_L_TO_H );
I was not aware of the SPI_XMIT_L_TO_H .
I just had
setup_spi(SPI_MASTER | SPI_L_TO_H | SPI_CLK_DIV_16 );
My slave was the same situation.
Thank You Mark!!!
PostPosted: Sun Apr 19, 2009 7:08 pm     Reply with quote
You have changed it from using SPI Mode 1, to Mode 0. Here are
the #define statements for the modes:
#define SPI_MODE_0  (SPI_L_TO_H | SPI_XMIT_L_TO_H)
#define SPI_MODE_1  (SPI_L_TO_H)
#define SPI_MODE_2  (SPI_H_TO_L)
#define SPI_MODE_3  (SPI_H_TO_L | SPI_XMIT_L_TO_H)
PostPosted: Mon Apr 20, 2009 2:04 am     Reply with quote
And as extra info: Master and Slave must have the same SPI mode setting.
What I don't understand is that how changing the SPI mode did solve your problem. As long as you had the Master and all Slaves configured for the same mode then your change can not have solved the underlying problem.
