i2c affecting interrupts
deperkin
PostPosted: Fri Apr 17, 2009 7:38 am     Reply with quote
Hello all!
I am trying to implement (and get working correctly) my i2c bus and RS232. I would also like to use interrupts.
I don't believe there is a need to post the code I have for this yet, since I have a vague question.
Am I really stuck with using the SCL and SDA pins?
I would prefer using these (on my 18F2331) for interrupts.
Since I only have three interrupts I would rather use these pins for INT1 and INT2 and have i2c communicate using two other pins.
Is this possible??
I have:
#define LCD_XMIT       PIN_A3   //LCD serial transmit
#define LCD_RCV        PIN_A3   //pin reused (receive not required
#define DEVICE_SDA   PIN_C4   //i2c SDA line
#define DEVICE_SLC    PIN_C5   //i2c SLC line
#define RS232_XMIT    PIN_C6   //RS232 serial transmit
#define RS232_RCV     PIN_C7   //RS232 serial receive
#use rs232(baud=2400,parity=N,xmit=LCD_XMIT,rcv=LCD_RCV,bits=8,invert,stream=LCD)
#use rs232(baud=115200,xmit=RS232_XMIT,rcv=RS232_RCV,parity=N,bits=8,stream=COMP)
#use i2c(master,sda=DEVICE_SDA,scl=DEVICE_SLC)
Thanks as always,
deperkin
rnielsen
PostPosted: Fri Apr 17, 2009 10:54 am     Reply with quote
If you're only going to use this PIC as a master then you can assign almost any pin for your SCL & SDA pins. The compiler will simply use software I2C to drive them. Simply place the proper pins in your #use i2c() statement and it should work.
Ronald
deperkin
I2c interrupts
PostPosted: Sat Apr 18, 2009 9:52 pm     Reply with quote
Thank you rnielsen!
I will try this. I am using two 18F2331's but the one in question is always running as master.
THank you for the help... i will try this.
