Addressing SFRs
Addressing SFRs
PostPosted: Thu Apr 16, 2009 4:04 pm     Reply with quote
I know how to do this:
 word ADCON1 = 0x02A0
bit_set(ADCON1,15);
But what do I need to define so that I can just say
ADCON1bits.ADON = 1;
yes, I realize that there are prewritten functions to turn on the ADC. But there are no prewritten functions to simultaneously sample 4 inputs. So I'm having to deal with lots of SFRs. Some of the microchip application notes have been very helpful, and I've actually gotten it to work.
Maybe this is heresy, but I'd like to use them in the same manner that C30 allows you to.
PostPosted: Thu Apr 16, 2009 4:11 pm     Reply with quote
You didn't post your PIC. I don't know what PIC has ADCON1 at 0x2A0.
I'm going to assume you're using the 16F-series. Here is Mark's header
file for accessing SFR registers:
http://www.ccsinfo.com/forum/viewtopic.php?t=20186
rnielsen
PostPosted: Thu Apr 16, 2009 5:05 pm     Reply with quote
Here's the way you can declare registers and then use the bit's name to assign values. This is a register for a PIC16F77:
#byte SSPCON = 0x14
//SSPCON bits
#bit SSPM0 = SSPCON.0
#bit SSPM1 = SSPCON.1
#bit SSPM2 = SSPCON.2
#bit SSPM3 = SSPCON.3
#bit CKP = SSPCON.4
#bit SSPEN = SSPCON.5
#bit SSPOV = SSPCON.6
#bit WCOL = SSPCON.7
CKP = 1;
Hope that helps.
Ronald
asmboy
PostPosted: Fri Apr 17, 2009 7:14 am     Reply with quote
these two related methods have always worked well for me in SFR land
#bit T0IF = 0x0B.2 // flag in reg
#byte PORT_B = 0x06
#BIT AUTOBOOSTOK = PORT_B.6 // inlet sense
#BIT BINTEG = PORT_B.7 // inlet sense
