H/W SPI on a pic24
Goto page Previous  1, 2, 3  Next
geokonst
PostPosted: Thu Apr 09, 2009 1:03 pm     Reply with quote
Ok I think I've done whatever there is to do to make this work (at least for a newbie).
I just don't get it.
This code:
#include "D:\...hardware.h"
#PIN_SELECT SDI1=PIN_G8
#PIN_SELECT SDO1=PIN_G7
#PIN_SELECT SCK1OUT=PIN_G6
#PIN_SELECT U2TX=PIN_F5
#PIN_SELECT U2RTS=PIN_F4
#use rs232(UART2,baud=19200,parity=N,bits=8)
#define SPI_CLK_DIV_2    0x001B
#define SPI_MODE_3 (SPI_H_TO_L)
#define cs PIN_B2
#define id 0x8f
#define getx 0xa9
#define gety 0xab
#define getz 0xad
int dataout;
main(){
setup_spi(SPI_MASTER | SPI_MODE_3 |SPI_CLK_DIV_1);
output_low(PIN_B15);
//who_am_i
output_low(cs);
spi_read(id);
dataout=spi_read(0);
putc(dataout);
output_high(cs);
//cfg
output_low(cs);
spi_read(0x20);
spi_read(0xC7); //11000011
output_high(cs);
while (1){
putc (0x80);
output_low(cs);
spi_read(getx);
putc(dataout);
output_high(cs);
output_low(cs);
spi_read (gety);
putc(dataout);
output_high(cs);
output_low(cs);
spi_read (getz);
putc(dataout);
output_high(cs);
Does not work (sends 80 and 3 zeroes to the serial port)
The same sequence with my software spi:
#include "C:\...uclboard.h"
#define in PIN_G8
#define out PIN_G7
#define clk PIN_G6
#define cs PIN_B2
#define id 0x8f
#define getx 0xa9
#define gety 0xab
#define getz 0xad
int recVal = 0x00;
int i;
void spisend(sendVal)
for (i=7;i>=0;i--){
output_bit(out,BIT_TEST(sendVal,i));
output_low(clk);
output_high(clk);
void spiread()
for (i=7;i>=0;i--){
output_low(clk);
if (input(in)){
    BIT_SET(recVal,i);
output_high(clk);
putc(recVal);
recVal=0x00;
output_high(clk);
//who_am_i
output_low(cs);
spisend(id);
//spiread();
output_high(cs);
//cfg
output_low(cs);
spisend(0x20);
spisend(0xC7); //11000011
output_high(cs);
while (1){
putc (0x80);
output_low(cs);
spisend(getx);
spiread();
output_high(cs);
output_low(cs);
spisend(gety);
spiread();
output_high(cs);
output_low(cs);
spisend(getz);
spiread();
output_high(cs);
Works perfectly!
both files have the same .h
#include <24FJ256GB106.h>
#FUSES NOJTAG                   //JTAG disabled
#FUSES ICS3                     //ICD communication channel 3
#FUSES WINDIS                   //Watch Dog Timer in non-Window mode
#FUSES WPRES128                 //Watch Dog Timer PreScalar 1:128
#FUSES WPOSTS16                 //Watch Dog Timer PostScalar 1:32768
#FUSES FRC_PS                   //Fast RC Oscillator with Post Scaler
#FUSES NOCKSFSM                 //Clock Switching is disabled, fail Safe clock monitor is disabled
#FUSES NOOSCIO                  //OSC2 is general purpose output
#FUSES NOPR                     //Pimary oscillaotr disabled
#FUSES IOL1WAY                  //Allows only one reconfiguration of peripheral pins
#FUSES WPEND_LOW
#FUSES NOWPCFG
#FUSES NOWPDIS
#FUSES WPFP0
#FUSES PLL12                    //Divide By 12(48MHz oscillator input)
#FUSES RESERVED                 //Used to set the reserved FUSE bits
#use delay(internal=8M)
...and were uploaded to the very same hardware one after the other.
Unfortunately I blew up my Explorer 16 board and can't use the scope any more, but last time I tried I got a good response from the accelerometer (LIS302DL) on h/w spi but the pic wouldn't read it. I can still use the serial though.
If anyone has an idea PLEASE PLEASE post it. This can't be so hard!
FvM
PostPosted: Thu Apr 09, 2009 2:44 pm     Reply with quote
I don't see anything wrong with your hardware SPI usage. Also the #pin_select commands seem to generate correct code.
geokonst
PostPosted: Thu Apr 09, 2009 3:48 pm     Reply with quote
What's going wrong then? It's driving me mad. Why doesn't it read a perfectly sent response? I really don't want to switch back to C30! I hate c30!
FvM
PostPosted: Thu Apr 09, 2009 4:15 pm     Reply with quote
It's not necessarily a PCD issue. Although hardware SPI should be able to communicate with the ST acceloremeter, there may be a problem with your hardware and the faster HW operation. I would try to trace it at the hardware level. You also could replace the device with a SDO/SDI loopback to verify basic send/receive operation.
geokonst
PostPosted: Thu Apr 09, 2009 4:35 pm     Reply with quote
But, you see the accelerometer is responding, so if it's a hardware issue it must be PIC's
The loopback is a very good idea!
geokonst
PostPosted: Thu Apr 09, 2009 6:41 pm     Reply with quote
The loopback test failed as well. I still get zeros. And I've tried different pins too. :(
FvM could the fact that I'm using the internal osc have anything to do with it? Doesn't sound likely but I'm running out of ideas.
FvM
PostPosted: Fri Apr 10, 2009 2:59 am     Reply with quote
As previously reported, hardware SPI is basically working with PIC24F chips, at least using the read_spi() instruction. I tested with V4.084 and most recent V4.090. Of course, I had to check with my hardware, that is using different pins, so it must not necessarily work with your configuration. I also can't see, if there's something in your hardware.h include file that disturbs SPI operation. Generally I would proceed like this:
- check the code operation at the assembly/register level with MPLAB debugger (requires e.g. ICD2 or PICkit ICSP adapter).
- check the hardware operation with an oscilloscope or other hardware debug tools
I don't expect problems related to internal oscillator.
Ken Johnson
PostPosted: Fri Apr 10, 2009 7:05 am     Reply with quote
I'm using SPI on 24H for 2 different devices (ADC and FRAM) at 2 different clock speeds, using (sorry) Microchip's C30. Here are some code snippets:
    SPI2STAT = 0;               //  Disable the SPI2 module for setup;
    SPI2CON1bits.CKP    = 0;    //  Clock idles lo;
    SPI2CON1bits.CKE    = 1;    //  Read data on rising edge of SCK;
    SPI2CON1bits.MSTEN  = 1;    //  PIC is the master;
    SPI2CON1bits.PPRE   = 2;
and
void    SaveFRAM (ushort offset, const void *pRAM, ushort nBytes)
//  Writes nBytes from pRAM into STORAGE at offset:
    const   dbyte   *p;
    ushort  nWords;
    nWords = nBytes / 2;        //  16-bit transfers;
    p = (dbyte*) pRAM;          //  Pointer to 16-bit items;
    TaskBlock (ProcessTask);    //  Shares the SPI Port;
    SPI2CON1bits.MODE16 = 0;    //  8-bit transfers on SPI2;
    SPI2CON1bits.SPRE   = 7;    //  10MHz (max SCLK);
    SPI2STATbits.SPIEN  = 1;    //  Enable the SPI module;
    SelectFRAM (0);             //  Chip Select;
    SPI2BUF = WREN;             //  Write the command and wait:
    while ( !SPI2STATbits.SPIRBF );
    SPI2BUF;                    //  Read buffer to clear SPIRBF;
    SelectFRAM (1);             //  Toggle Chip Select;
    SelectFRAM (0);             //  Write the next command:
    SPI2BUF = WRITE;
    SPI2STAT = 0;               //  Disable the SPI, and change mode:
    SPI2CON1bits.MODE16 = 1;    //  Now do 16-bit transfers;
    SPI2BUF = offset;           //  Write the address;
    while ( nWords-- ) {        //  Now write all the data:
        SPI2BUF = *p++;
        SPI2BUF;
    SelectFRAM (1);
    SPI2STAT = 0;               //  Disable PIC SPI, and clear the read overrun flag;
    TaskUnBlock (ProcessTask);
Maybe comparing this with the CCS generated asm code will show something?
Best of luck!
Ken
PostPosted: Sat Apr 11, 2009 9:11 am     Reply with quote
geokonst-
I've made some progress over the last day or so, however I've done so using software SPI similar to what you've posted. Still nothing with the hardware (and still waiting for a response from Microchip). I was attempting to use port D on the PIC, of which one of the pins I was using apparently didn't work. However I tried port G like you were using and still didn't get a response. I'll keep you posted if I hear back from Microchip or get the hardware to work.
FvM
PostPosted: Sat Apr 11, 2009 11:15 am     Reply with quote
I would be suprized, if there's a hardware problem with certain pins, but can be, of course. Anyway, it's interesting to know, which part of the SPI function is apparently failing: SCK, SDO or SDI/receive.
geokonst
PostPosted: Sat Apr 11, 2009 5:32 pm     Reply with quote
I have too tried pins D1, D2, D3, G8, G7 with no luck (no compiler errors). I don't believe its a pin problem as pps works fine with the serial port. Also I've tried manually setting I/O direction.
The customer support sent me the following code which they say compiles:
#include <24fj256ga110.h>
#use delay(clock=40mhz)
#PIN_SELECT SS1OUT=PIN_B1
#use rs232(UART1,baud=19200,parity=N,bits=8)
#use spi(SPI1, BITS=16, MODE=3)
int dataout;
void main(){
while (1){
output_low (PIN_B2);
dataout=SPI_XFER(0x8f);
output_a(dataout);
delay_us(50);
output_high (PIN_B2);
delay_ms(3);
It doesn't compile for me and the problem is the option "SPI1" in use spi. I have no idea why. Could you please try it and let me know if it compiles on your machine?
I have also tried the registers approach:
#include "D:\...24FJ256GB106_registers.h"
#PIN_SELECT SDI1=PIN_D1
#PIN_SELECT SDO1=PIN_D3
#define SPI_MASTER 0x0120 // select 8-bit master mode, CKE=1, CKP=0
#define SPI_ENABLE 0x8000 // enable SPI port, clear status
#define cs PIN_B2
int i;
int writeSPI2( int data)
SPI2BUF = data;
return SPI2BUF; // read the received value
main()
output_high (cs);
SPI2CON1 = SPI_MASTER; // select mode
SPI2STAT = SPI_ENABLE; // enable the peripheral
while (1){
set_tris_d(0xfc);
output_low(cs);
writeSPI2( 0x8F); // send a READ STATUS COMMAND
i = writeSPI2( 0); // send dummy, read data
putc(i);
delay_ms(10);
output_high(cs);
delay_ms(10);
[/quote]
But I am really inexperienced so I probably have done something wrong.
So what is failing for me is reading the response (or putting the value in a variable). While I had access to an oscilloscope I could see that the communication was perfect. And I have also tried sorting sdi + sdo and still nothing. So SDI seems to be the problem.
Unfortunately I need hardware spi, so if you have any ideas please post them here. Thanks
FvM
PostPosted: Sat Apr 11, 2009 6:08 pm     Reply with quote
I didn't try #use spi with V4.090. As said, it didn't work with V4.084, at least for PIC24FJ128GA106 (and similar GA10x and GB10x chips). As a possible problem, CCS seems not to test built-in functions with the full choice of chips, so a lot of bugs related to chip specific features, register mappings etc. isn't detected.
I don't understand your "register approach", that uses #pin_select for SPI1 but accesses SPI2 registers. This can't work.
geokonst
PostPosted: Sat Apr 11, 2009 6:28 pm     Reply with quote
Lol of course not Smile. I've done so many changes trying to make this work that it's hard to find a file with correct code any more. Sorry for that. I don't even remember the reason why I switched to spi2 after some point.
Thanks Fvm.
Guest have you given up on H/W spi?
geokonst
PostPosted: Wed Apr 15, 2009 6:12 pm     Reply with quote
And here's some proof that the comms are fine (although I can't read the response)
I've also learned that #use spi won't work with versions <4.084 (unfortunately mine) and apparently I can't make setup_spi work either so no h/w spi for me.
FvM
PostPosted: Thu Apr 16, 2009 4:08 am     Reply with quote
Can you please show the code, that is producing the shown waveform (and fails on recepetion). I see, that it can't be the code you posted most recently. And also tell the compiler version (you possibly did before).
As previously said, I have no problems with hardware SPI, using V4.084 and V4.090.
Page 2 of 3
