pic-gsm
angela
pic-gsm
PostPosted: Tue Apr 14, 2009 1:41 pm     Reply with quote
I have a PIC(18F97j60) board with built in GSM capability (must insert valid SIM card into board) that I'm programming. The board came bundled with code, however the code didn't seem to be correct because I can not get the damn thing to send a text message. If you look at the code, the send_sms function along with many of the other functions were set up with the use of a web form in mind (as a means of data input (phone number and message content). However, I simply want to hard code the sms number and message and have the board send a text once it's powered on. You can see that's what I tried to do in the send_sms function, but there is something not right. I'm thinking its my AT command syntax. Any help would be greatly appreciated since i'm not a programmer but I do have to complete this task.
int send_sms(char * number,char * message,int timeout)
int tmt=timeout;
//int k=sizeof(LCDText);
tmp[0]='A';
tmp[1]='T';
tmp[2]='+';
tmp[3]='C';
tmp[4]='M';
tmp[5]='G';
tmp[6]='S';
tmp[7]='=';
tmp[8]='"';
tmp[9]='+';
//memcpy(tmp+10,LCDText,number_length);
memcpy(tmp+10, number, number_length);
tmp[number_length+10]='"';
tmp[number_length+11]='\0';
//SendUART2(tmp);
//SendUART2("AT+CMGF=1");
//SendUART2("AT+CMGS=\"9086161265\"");
//SendUART3(message);
SendUART("AT");
SendUART("AT+CMGF=1");
SendUART("AT+CMGS=\"+19086161265\"");
SendUART3("TEST");
//add handle for custom GSM number
a=65535;
//while(--a!=0);
if (rx_counter != 0)
while(!(proba == '>')) //HERE sending SMS works
proba=getchar_UART(70000);
SendUART3(message);
}//end sending
//if(!waitplus(7000))
return 0;
do
a=a;
while((proba != 10)&& (--timeout!=0)); //skip first line, read message text on second line
if(!waitOK())
return 0;
a=65535;
return 1;
Please help with receiving/reading texts from the sim card. Does anyone know how to read the text messages of the sim card?
with regards, Ada
PostPosted: Tue Apr 14, 2009 1:56 pm     Reply with quote
SendUART3("TEST");
This is probably C18 compiler code. It look like you copied it from here:
http://www.gidforums.com/t-20863.html
Do you have the CCS compiler ? It's not directly compatible with the
Microchip C18 compiler.
If you do have the CCS compiler, then use the forum's search page to
search for: GSM
http://www.ccsinfo.com/forum/search.php
I did that and I got 150 hits. Try it.
