Trying to enable interrupt on PIN_B0
seme1
PostPosted: Mon Apr 13, 2009 6:21 pm     Reply with quote
Version : 4.013
Pic: PIC18F4550
I am trying to enable interrupts on RB0 with no luck so far. It's working fine for pins B4 ,B5,B6, and B7 but not B0. Any idea why ? or how to fix this ?
The code I'm using is the following:
#int_rb
void myfunc_isr() {
     int8 dd;
customflag=6;
   dd = input_B();
  SET_TRIS_B(0xFF);
  ext_int_edge(L_TO_H);
  port_b_pullups(TRUE);
  clear_interrupt(INT_RB);
  ENABLE_INTERRUPTS(INT_RB);
  ENABLE_INTERRUPTS(INT_RTCC);
  ENABLE_INTERRUPTS(INT_RDA);
  ENABLE_INTERRUPTS(GLOBAL);
setup_adc(ADC_OFF);
while (customflag !=-1){
   lcdputc("interrupt_driven");
   customflag =-1;}
PostPosted: Mon Apr 13, 2009 6:56 pm     Reply with quote
I don't know if this is your problem, but on most PICs, pin B0 is the external interrupt pin. The CCS interrupt handler for this pin is usually INT_EXT rather than INT_RB. In any event, it's an easy thing to test.....
Jeff
PostPosted: Mon Apr 13, 2009 8:48 pm     Reply with quote
Hi Again,
I checked the datasheet for the 18F4550 and it has three external interrupt pins INT0, INT1, and INT2, so the solution to your problem will be to use the EXT_INT0 interrupt handler.
Jeff
