It seems not possible to use 'stream' with #int_rda
theteaman
PostPosted: Sun Apr 12, 2009 1:57 am     Reply with quote
It seems that including a stream identifier in a use rs232, such as
#use rs232(baud=38400, xmit=PIN_C6, rcv=PIN_C7, PARITY=N, STREAM=B1)
causes a serial hardware interrupt to never be triggered. Removing the stream identifier, makes everything work! Eg.
#use rs232(baud=38400, xmit=PIN_C6, rcv=PIN_C7, PARITY=N)
The stream identifier is not currently used in any way so it cannot be causing the code to fail somehow.. can anyone explain a way around this? Below is the code:
#use rs232(baud=38400, xmit=PIN_C0, PARITY=N, STREAM=B2)
#INT_RDA
void rda_isr(void)
      unsigned char c = getc();
      if(c=='a') output_high(PIN_B7);
   enable_interrupts(global);
   enable_interrupts(int_rda);
   set_tris_b(0);
   set_tris_c(0b10000000);
As stated above, removing the 'stream=b2' makes everything work with the interrupt being called properly. Any help appreciated, thanks.
PostPosted: Sun Apr 12, 2009 2:48 am     Reply with quote
Unfortunately, you didn't either mention a chip or a compiler version.
Generally, when you use a stream identifier with the hardware UART, also the ISR getch() must be changed to fgetc(). Did you?
To save us further guesses, please give a complete (minimal) code example of the non-working stream version.
theteaman
PostPosted: Sun Apr 12, 2009 6:41 am     Reply with quote
FvM, replacing the getc with fgetc(stream) worked.. thanks for your help! Smile
