nooby
16f877a input and output defining... |
Posted: Fri Apr 10, 2009 10:12 am |
Hi everyone out there...
I'm trying to write a code to a 16f877a and I had tried to simulate the following code. However, when I troubleshoot and inject a 5V to the input pin to trigger and hoping for the output LED to light, it doesn't work.
Anyone can lighten my queries?
Code: | #include <16F877.H>
#FUSES HS,NOWDT,NOLVP
#USE DELAY(clock=12000000)
#USE RS232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8)
#DEFINE SIREN PIN_B7
#DEFINE RED PIN_B4
#DEFINE YELLOW PIN_B3
#DEFINE GREEN PIN_B2
#DEFINE TOUCH PIN_A1
#DEFINE LIGHT PIN_A2
#DEFINE DOOR PIN_A3
#DEFINE PANIC PIN_A4
//Turning On The Siren
void SIREN_ON()
OUTPUT_HIGH(SIREN);
//Turning On The Red LED
void RED_ON()
OUTPUT_HIGH(RED);
//Turning On The Yellow LED
void YELLOW_ON()
OUTPUT_HIGH(YELLOW);
//Turning On The Green LED
void GREEN_ON()
OUTPUT_HIGH(GREEN);
//Main Function
void MAIN()
setup_timer_1(T1_DISABLED);
SET_TRIS_A(0xFF);
SET_TRIS_B(0x00);
SET_TRIS_C(0x0F);
SET_TRIS_D(0x00);
SENSOR1=INPUT(TOUCH);
SENSOR2=INPUT(LIGHT);
SENSOR3=INPUT(DOOR);
SENSOR4=INPUT(PANIC);
while(1){
if(SENSOR1)
SIREN_ON();
RED_ON();
else if(SENSOR2)
SIREN_ON();
YELLOW_ON();
else if(SENSOR3)
SIREN_ON();
RED_ON();
else if(SENSOR4)
SIREN_ON();
The input of A1 to A4 is suppose to be connect to sensor with approximate 5V input to the pin when trigger, while the output will be 5v to the LED. |
Posted: Fri Apr 10, 2009 10:25 am |
while(1){
You are reading the sensors outside of the loop. If your program is
already running, it will be in the while() loop. It can't get any more
updates from the sensors. Put the sensor reading inside the loop.
It's also a good idea to put a delay_ms(100) statement (or more)
inside the loop to debounce the inputs.
Also, the standard in C is to use lower case (or mixed case) for function
names and variables. Upper case is mostly reserved for constants
(#define statements). |
