PWM Measurement with Capture PIC24
richi-d
PostPosted: Thu Apr 09, 2009 4:45 am     Reply with quote
Hi All,
I´m trying to measure Servo pulses, but I donßt get an interrupt with my code:
// V01 10.03.2009
#include <24FJ128GA106.h>
#FUSES FRC_PLL,NOPROTECT,NOIESO,NOJTAG,ICSP1,DEBUG
#use delay (clock=32000000)
#pin_select OC2=PIN_D11
#pin_select OC3=PIN_D10
#pin_select OC4=PIN_D9
#pin_select OC8=PIN_D8
#pin_select IC1=PIN_G7
#USE STANDARD_IO(B)
#USE STANDARD_IO(C)
#USE STANDARD_IO(D)
#USE STANDARD_IO(E)
#USE STANDARD_IO(F)
#USE STANDARD_IO(G)
#define _NOP   #asm NOP #endasm;
#define TESTPIN      PIN_F5
#define PWM_IN      PIN_G7
long      PWM_IN_STARTWERT;
long      PWM_IN_STOPWERT;
#int_IC1
void  IC1_isr(void)
   if (input(PWM_IN))
      PWM_IN_STARTWERT = get_capture(1,0);
      setup_capture(1, CAPTURE_FE |CAPTURE_TIMER2);
   if (!input(PWM_IN))
      PWM_IN_STOPWERT = get_capture(1,0);
      setup_capture(1, CAPTURE_RE |CAPTURE_TIMER2);
   ENABLE_INTERRUPTS(INTR_GLOBAL);
   SETUP_TIMER2(TMR_INTERNAL | TMR_DIV_BY_8);   // 65535µs   Überlauf, 1µs 1 Increment
   SETUP_CAPTURE(1, CAPTURE_RE | INTERRUPT_EVERY_CAPTURE | CAPTURE_TIMER2);
   ENABLE_INTERRUPTS(INT_IC1);
   for(;;)
   delay_ms(250);
      }//   for(;;)
   }//Main()
Is there a better method to do that?
richi-d
PostPosted: Thu Apr 09, 2009 6:02 am     Reply with quote
I now tried this Version:
   *0x142 = 0x0C01;   //IC1CON2
   *0x140 = 0x0403;   //IC1CON1
   for(;;)
      delay_ms(250);
      }//   for(;;)
   }//Main()
The program jumps now into the interrupt, but doesn´t have any value in the IC1BUFFER. Because after *0x140 = 0x0403; //IC1CON1 i always have 0x1B in the IC1CON1... Why do I not find my value 0x403 in the 0x140 register?
richi-d
PostPosted: Thu Apr 09, 2009 7:58 am     Reply with quote
All Adresses are wrong in the Compiler CCS!!
For Example:
   SETUP_COMPARE(1, COMPARE_SINGLE_PULSE | COMPARE_TIMER3);
This writes to the Adress 0x184 (IC9BUF)
Twisted Evil I´m sooooo angry!!! The whole day for nothing! How can I write a 16bit value directly to the adress?
With: *0x142 = 0x0C01; it seems that I only can write 8bit....
PostPosted: Thu Apr 09, 2009 12:03 pm     Reply with quote
Some of.
By using standard C syntax!
*(int16*)0x142 = 0x0C01;
A better readable CCS specific version, that's used through all examples is this:
#word IC1CON2 = 0x142
IC1CON2 = 0x0C01;
You can also utilize the Device Editor Tool to generate an include file with all device specific SFR addresses. Or correct some wrong SFR addresses.
