RealICE with CCS
Heath
RealICE with CCS
PostPosted: Thu Apr 09, 2009 10:41 am     Reply with quote
Does anyone use the RealICE as a programmer after building with CCS?
I can 'successfully' program and verify the device. I say 'successfully' because once it is done the controller doesn't operate as I think it should.
I have another ICSP programmer that I can program this hex file with and then the controller operates as I think it should.
Has anyone experienced this? My buddy at work uses Microchip's C18 compiler and hasn't had a problem with his RealICE. I thought it might be CCS?
asmallri
Re: RealICE with CCS
PostPosted: Thu Apr 09, 2009 10:42 am     Reply with quote
Heath wrote:
Does anyone use the RealICE as a programmer after building with CCS??
Yes however I use the Microchip IDE
Regards, Andrew
Heath
PostPosted: Thu Apr 09, 2009 10:46 am     Reply with quote
You don't have any problems programming; problems like I've described?
Heath
PostPosted: Thu Apr 09, 2009 12:07 pm     Reply with quote
I programmed with the RealICE then verified it with another ICSP programmer that I have and it didn't check out.
Andrew, did you do anything special to make it work for you?
asmallri
PostPosted: Thu Apr 09, 2009 1:11 pm     Reply with quote
No - plugged it it, selected it as the programmer in MPLAB and programmed away...
I am using MPLAB 8.10
Regards, Andrew
