string modem Gm862 Telit
staminale
PostPosted: Fri Mar 27, 2009 6:36 am     Reply with quote
Hi!
how to handle these strings? whether the calls are in phone book in or not?
there is a code to get started?
+CLIP: "",128,"",128,"",2 //hidden number
+CLIP: "+3933812345678",145,"",128,"",0 //is not in the phone book
+CLIP: "+3933812345678",145,"",128,"Giacomo" //is in the phone book
PostPosted: Fri Mar 27, 2009 1:55 pm     Reply with quote
http://www.ccsinfo.com/forum/search.php
Try keywords like:
- telit
- CMGS (the AT command for sending a text message)
staminale
PostPosted: Mon Mar 30, 2009 8:54 am     Reply with quote
Hi!
You can find a sequence without using the library string.h?
rufflos
PostPosted: Tue Apr 07, 2009 9:34 am     Reply with quote
hi, staminale
how can you get those strings from the gsm module? i have the same module but i cannot get any string trough rs232, what did you do? thank you, i'm waiting for your response.
staminale
PostPosted: Tue Apr 07, 2009 12:37 pm     Reply with quote
rufflos wrote:
hi, staminale
AT+CLIP=1
rufflos
PostPosted: Tue Apr 07, 2009 3:06 pm     Reply with quote
oh, thank you but i mean, how do you manage to get somethin readable from the rcv pin? i cant get nothing more than a 0x00
i have tried the AT command that is supposed that the answer is OK, but i only get a 0x00 (end of string)
could you put the code you used for obtaining that responses?
thank you.
staminale
PostPosted: Fri Apr 10, 2009 5:52 pm     Reply with quote
Hi!
here's how I did, you tell me if good, if there are more efficient systems.
#include <16F877a.h>
#include <setting.h>
#include <string.h>
#include <input.c>
#define  STRING_SIZE    51
void call_modem(char *calling)
    if (calling[8] == '"') //hidden number
        printf ("\n%s", "hidden number");
        {if(calling[strlen(calling) - 1] == '0') // The last character is a zero
         printf ("\n%s", "is not in the phone book");
         if(calling[strlen(calling) - 1] == '"') // The last character is "
         printf ("\n%s", "is in the phone book");
void main() {
char input_str[STRING_SIZE];
while(true)
get_string(input_str,STRING_SIZE);     // gets the string
call_modem(input_str);
volcane
Re: string modem Gm862 Telit
PostPosted: Sun Apr 12, 2009 4:46 pm     Reply with quote
staminale wrote:
Hi!
the string is wrong with the modem gm862 puts an end 0
+CLIP: "+3933812345678",145,"",128,"Giacomo",0
