PIC24/PCD doesn't work
richi-d
PostPosted: Tue Apr 07, 2009 8:15 am     Reply with quote
I try to make a very simple program, but this is not running. The pin doesn't toggle. Oscillator is running. Do I have to map the output pins somehow?
#include <24FJ128GA006.h>
#FUSES FRC_PLL,NOPROTECT,NOIESO,NOJTAG,ICSP1,DEBUG
#use delay (clock=32000000)
#USE STANDARD_IO(B)
#USE STANDARD_IO(C)
#USE STANDARD_IO(D)
#USE STANDARD_IO(E)
#USE STANDARD_IO(F)
#USE STANDARD_IO(G)
#define _NOP   #asm NOP #endasm;
#define RD         PIN_E0
#define WR         PIN_E1
#define A0         PIN_E2
#define RST         PIN_E3
#define CS         PIN_E4
#define DATA_0      PIN_D7
#define DATA_1      PIN_D6
#define DATA_2      PIN_D5
#define DATA_3      PIN_D4
#define DATA_4      PIN_D3
#define DATA_5      PIN_D2
#define DATA_6      PIN_D1
#define DATA_7      PIN_D0
#define TESTPIN      PIN_F5
#include <string.h>
int         DATA;
int         COMMAND;
int         PAGE;
int         i;
int         x;
int         XPOS;
int         KLEIN[11][5];
int         GROSS[10][8][2];
int         KLEIN_2[10][8][2];
int         GROSS_2[11][8][2];
int         AUSSCHNITT;
int         AUSSCHNITT_INVERS;
int         UNITS;
int         TENS;
int         HUNS;
int         THOUS;
long      j;
int         k;
long      n;
int32      VOLLE_PIXEL_L;
int32      VOLLE_PIXEL_H;
#include "Display_Steuerung.h"
#include "Display_Steuerung.c"
   Display_Init();
   delay_ms(5);
   Display_Logo();
   for(;;)
      output_high(TESTPIN);
      delay_us(1);
      output_low(TESTPIN);
      delay_us(1);
      }//   for(;;)
   }//Main()
This is my second problem. There are errors when compiling:
#pin_select OC2=PIN_D11
#pin_select OC3=PIN_D10
#pin_select OC4=PIN_D9
#pin_select OC5=PIN_D8
#pin_select IC1=PIN_G7
*** Error 7 "Testboard_PWM_V01.c" Line 10(12,24): Invalid Pre-Processor directive Invalid Pin
*** Error 7 "Testboard_PWM_V01.c" Line 11(12,24): Invalid Pre-Processor directive Invalid Pin
*** Error 7 "Testboard_PWM_V01.c" Line 12(12,23): Invalid Pre-Processor directive Invalid Pin
*** Error 7 "Testboard_PWM_V01.c" Line 13(12,23): Invalid Pre-Processor directive Invalid Pin
*** Error 7 "Testboard_PWM_V01.c" Line 15(12,23): Invalid Pre-Processor directive Invalid Pin
richi-d
Next Problem:
PostPosted: Tue Apr 07, 2009 8:23 am     Reply with quote
This PIC has 9 input captures and 9 output compares, but it seems CCS supports only 5!!
#pin_select OC8=PIN_D8
*** Error 7 "Testboard_PWM_V01.c" Line 84(12,23): Invalid Pre-Processor directive Invalid Pin ID
Question: is the PCD a BETA compiler? It seems to me as there are a lot of problems!!
PostPosted: Tue Apr 07, 2009 11:19 am     Reply with quote
Do I have to map the output oins somehow?
No. Depending on the code part not shown in your listing, the said main loop is possibly never executed. Also RF5 may be configured to another I/O function overriding the port function. With Display_xx() functions commented out, pin F5 should toggle.
Depends on your definition of a BETA compiler. If it excludes a product sold for the full retail price, it isn't.
richi-d
PostPosted: Tue Apr 07, 2009 2:10 pm     Reply with quote
The loop is entered as I can debug the code step after step!
In the Display routines are just Pins going High and Low. The pins I declared above. This does also not work!
How can I use all 9 Input captures and output compares? I need them all...
PostPosted: Tue Apr 07, 2009 2:37 pm     Reply with quote
As you mentioned 9 output compare functions, it gave me the idea, that you are simply using the wrong chip definition. GA006 actually has only 5 OC functions while GA106 has 9, and both have different SFR addresses for IO ports, so obviously the code can't work.
richi-d
Thanks!
PostPosted: Wed Apr 08, 2009 12:16 pm     Reply with quote
Hi FvM, this was really helpful! The compiler works good now. I´m really happy. I ´m sorry that I doubt at CCS, but I was searching 2 hours for this little mistake, and I think without your help I would still search!!
zhzhou
PostPosted: Thu Apr 30, 2009 3:11 pm     Reply with quote
I'm having a similar problem on the PIC24FJ64GB106. The hardware definitely supports 9 PWM ports, but the compiler is only letting me setup PWM interrupts on 5 of them (OC1 to OC5). It gives me "Invalid Pre-Processor directive" on the lines the contain #int_ocX where X = 6 to 9.
I'm sure that I have the correct device chosen in MPLAB and also the correct include file. In fact, the include file only has definitions for OC1 to OC5, OC6 to OC9 don't seem to exist!
Any idea on how I can access the interrupts for OC6 to OC9?
PostPosted: Thu Apr 30, 2009 3:40 pm     Reply with quote
If they have been forgotten in the device configuration, you can't. Report the issue to CCS support. At best, the interrupts are already provided as an option and can be enabled in the Device Editor tool.
