Hi I'm trying to download the example EX10 code from the exercise book to the sensor board but it always says: 'Could not detect the target chip. Target detection problems may be due to the ICD firmware not supporting your target chip's family type. The current ICD firmware supports the following targets: PIC16 PIC18 DSPIC. To use firmware that does support your target's device family, use the update firmware button and select the appropriate firmware from the latest compatible firmware list.'
But i don't have problems to program and debug the coordinator board. The sensor board has a 16f886 pic and the coordinator board has a 18f4620 pic. What should I do?
