Problem with INTRC_IO (fuses)
Chevi
PostPosted: Fri Apr 03, 2009 7:27 am     Reply with quote
Hi...
I have the PIC18F4620. I connected a external oscillator, 4MHz. I would like a fastest frequency.
Can I multiply this frequency by 4 with PLL? and obtain a 16MHz?
Can I use the internal RC with the oscillator connected? I compile my program with #fuses INTRC_IO and obtain this message:
"Could not start target. The target has not........ . Use View | Valid fuses to find the correct clock fuse."
Best regards.
PostPosted: Fri Apr 03, 2009 12:55 pm     Reply with quote
See this thread. It recommends to get the lastest ICD firmware.
Apparently, if you do the downloading from within the ccsload program, then it will find and get vs. 2.53 ICD firmware, which fixes the problem:
https://www.ccsinfo.com/forum/viewtopic.php?t=38312
Chevi
PostPosted: Sat Apr 04, 2009 5:33 am     Reply with quote
I updated the firmware and the problem persists.
Thank you.
PostPosted: Mon Apr 06, 2009 3:22 am     Reply with quote
Any suggestion?
