16F628A
angela
16F628A
PostPosted: Mon Mar 30, 2009 8:15 am     Reply with quote
Does 16F628A work with ICD-U40?
PostPosted: Mon Mar 30, 2009 11:02 am     Reply with quote
This thread explains it:
http://www.ccsinfo.com/forum/viewtopic.php?t=23672
It's about a 16F627A, but it also applies to the 16F628A.
angela
CCS's standalone program
PostPosted: Tue Mar 31, 2009 12:27 pm     Reply with quote
CCS has a Standalone program for the ICD-U40...do you mean that .exe ICD Interface Programming...I need this pic (16F628A) only for programming and i'm not getting how it works! I have kit150 too!
regards, angela
PostPosted: Tue Mar 31, 2009 1:22 pm     Reply with quote
If you only want to program the PIC, then you don't need the ICD header.
You can use the ICD-U40 as a programmer with the CCSLOAD program:
http://ccsinfo.com/content.php?page=ccsloadsw
Also, the ICD-U40 can only be used for debugging if you have the
CCS IDE compiler, such as PCW, PCWH, etc. ICD-U40 will not debug
with MPLAB, and it won't debug with the CCSLOAD program.
