Weird problem using external memory driver
JimNewbie
PostPosted: Sun Mar 29, 2009 5:22 am     Reply with quote
hi,
I came across this problem and I hope that someone would help me to understand it.
Here is the problematic code:
#define PIC188F88722_EXT_MEM_START 0x20000L
typedef struct
  uint32   start_addr;
  uint32   end_addr;
  uint8     num_block;
} my_test_ext_mem_stype;
my_test_ext_mem_stype my_test_ext_mem;
// This function is having problem
void test_mem_function (void)
  uint16  temp_read, temp_write, index;
  my_test_ext_mem.start_addr = PIC188F88722_EXT_MEM_START ;
  for (index = 0; index < 1000; index++)
    temp_write = index + 33;
    write_external_memory(my_test_ext_mem.start_addr ,&temp_write,2);
    read_external_memory(my_test_ext_mem.start_addr ,&temp_read,2);
    if (temp_write != temp_read)
      temp_read = temp_write;  <<<----- It will hit here alot
Also the same function, If I modify it like this, my test memory will be passed.
  uint32  start_address;
  start_address = PIC188F88722_EXT_MEM_START ;
    write_external_memory(start_address ,&temp_write,2);
    read_external_memory(start_address  ,&temp_read,2);
      temp_read = temp_write;  <<<----- won't hit here.
or like this, still work
    write_external_memory(PIC188F88722_EXT_MEM_START ,&temp_write,2);
    read_external_memory(PIC188F88722_EXT_MEM_START ,&temp_read,2);
or even this also works
  my_test_ext_mem.start_addr = (PIC188F88722_EXT_MEM_START - 2) ;
    write_external_memory(my_test_ext_mem.start_addr + 2 ,&temp_write,2);
    read_external_memory(my_test_ext_mem.start_addr + 2,&temp_read,2);
      temp_read = temp_write;  <<<----- won't hit here. Good to go
Please help me to explain this kind of weird behavior.
Thank you
JimNewbie
PostPosted: Sun Mar 29, 2009 5:31 am     Reply with quote
btw, I was using CCS 4.087 and I just update the new version 4.090. Both have the same problem.
It is PIC 18F8722.
