dspic30F3011.. Not Output PWM!!!!
ploveq
PostPosted: Fri Mar 27, 2009 10:08 pm     Reply with quote
** PWM PORT : PWM1_H(PIN RE1)
PWM2_H(PIN RE3)
PWM3_H(PIN RE5)
** MCU : dspic30F3011
#include <30F3011.h>
#FUSES HS                       //High speed Osc (> 4mhz)
#FUSES FRC
#FUSES NOPWMPIN
#FUSES PR                       //Promiary Oscillator
#FUSES PWMPIN
#FUSES HPOL_HIGH                //High-Side Transistors Polarity is Active-High (PWM 1,3,5 and 7)
  //PWM module high side output pins have active high output polarity
#FUSES NOPWMPIN                 //PWM outputs drive active state upon Reset
#use rs232(baud=9600, UART2,stream=pc_host)
char pc_data[20];
int i;
int mun =0;
int LED_Flag;
int no_flag;
int bat;
int temp;
int delay_flag = 0;
int16 duty;
int16 OCR_2;
int16 OCRS_2;
#INT_RDA2
void rda_isr()
    pc_data[0] = fgetc(pc_host);
    if(pc_data[0]=='S')
      pc_data[1] = getch(pc_host);
      pc_data[2] = getch(pc_host);
       output_bit(pin_E1,1);         //GREEN
       output_bit(pin_E1,0);         //GREEN
        delay_ms(1);
        #use rs232(baud=19200, UART1A)
        printf("%c%c",0xa3,1);
        printf("%c%c%c",0xa1,0,0);
        printf("%c Roll Indy Check  %c",0xa2,0);
   output_bit(pin_E8,0);         //RS485 Enabled
   enable_interrupts(INT_RDA2);
//duty = 32768; // = 0.5 * 65536
  duty = 502768; // = 0.5 * 65536
  setup_timer3(TMR_INTERNAL | TMR_DIV_BY_1);
  set_pwm_duty(3, duty);
  setup_compare(3, COMPARE_PWM);
    while(true)
      if((pc_data[0]=='S') && (pc_data[1]=='L') && (pc_data[2]=='1')   )
            pc_data[0] = 'A';
      if((pc_data[0]=='S') && (pc_data[1]=='L') && (pc_data[2]=='2')   )
            output_bit(pin_E3,1);         //GREEN
            output_bit(pin_E3,0);         //GREEN
            pc_data[0] = 'A';
      if((pc_data[0]=='S') && (pc_data[1]=='L') && (pc_data[2]=='3')   )
            output_bit(pin_E5,1);         //GREEN
            output_bit(pin_E5,0);         //GREEN
            pc_data[0] = 'A';
        i++;
        printf("%c%c%c",0xa1,0,1);
        printf("%c da= %c %c / %c / %c %c",0xa2,pc_data[0],pc_data[1],pc_data[2],i,0);
