24fj16ga002 irda enable
guest897
PostPosted: Thu Mar 26, 2009 1:43 pm     Reply with quote
Hi all,
I am using pic24fj16ga002 for my project and I want to use irda encoder and decoder option. My code is:
#include <24FJ16GA002.h>
#include <string.h>
#pin_select U1TX=PIN_B10  //RS-232 TX PIN 21
#pin_select U1RX=PIN_B11  //RS-232 RX PIN 22
#pin_select U2TX=PIN_B14  //RS-232 TX PIN 21
#pin_select U2RX=PIN_B15  //RS-232 RX PIN 22
#use rs232(UART1,BAUD=19200, STREAM=PC1)
#USE RS232(UART2,BAUD=19200, STREAM=PC)
But I don't know how to enable irda option. Data sheet says IREN=1 but but how I will define this? Does anyone has example code or idea about this?
Thanks.
PostPosted: Thu Mar 26, 2009 3:01 pm     Reply with quote
Define it straightforward according to the SFR address in the datasheet, e.g.
#bit U1_IREN = 0x221.4
U1_IREN = 1;
