measure frequency prescaler
volcane
PostPosted: Wed Mar 25, 2009 3:29 pm     Reply with quote
Hi!
I need a pin-out (example b5) on a 16F877 the exact frequency of timer1 prescaler? I would like to measure with frequency meter the frequency of the prescaler.
I recommended that code?
PostPosted: Wed Mar 25, 2009 3:47 pm     Reply with quote
There is no way to bring the Timer1 Prescaler clock to an i/o pin.
There is no option in the 16F877 hardware to do this.
volcane
PostPosted: Wed Mar 25, 2009 3:55 pm     Reply with quote
you can do with software? I would like to know the error of the oscillator
PostPosted: Wed Mar 25, 2009 4:16 pm     Reply with quote
You have full control over the application program in the PIC.
You can create a loop that toggles a pin. Example:
#include <16F877.H>
output_low(PIN_B5);
#use fast_io(b)
  output_high(PIN_B5);
  output_low(PIN_B5);
Then look at the .LST file to see what ASM code is generated by the
compiler:
.................... while(1)
....................   output_high(PIN_B5);
0010:  BSF    PORTB.5
....................   output_low(PIN_B5);
0011:  BCF    PORTB.5
0012:  GOTO   010
That's a total of 4 instruction clocks. The BSF and BCF each take 1 clock.
The GOTO takes 2 clocks. So the signal on pin B5 will be the instruction
clock divided by 4. The instruction clock is 1/4 of the crystal frequency,
so it's 1 MHz. Then the loop above divides it by 4, to give 250 KHz on
pin B5. You can measure that with an oscillocope or frequency meter.
volcane
PostPosted: Thu Mar 26, 2009 2:35 pm     Reply with quote
Thanks works perfectly
