16F526 RC0, RC1& RC2 generate pulses when DELAY_MS(XX)
orb
PostPosted: Wed Mar 25, 2009 8:33 am     Reply with quote
Hi all,
I am having a very strange problem with the 16F526. I am using it to drive pins B4, B5, C0, C1 & C2 but the device begins generating periodic square pulses on C0, C1 & C2 with the following simple code.
Here's what's weird, C0 puts out a 123kHz pulse, C1 a 61.6kHz and C2 a 30.8kHz instead of just toggling off/on once with a 500ms delay in between.
What's more interesting is that if I remove the "DELAY_MS(500);" line
C0, C1 & C2 stop generating the pulses I described above.
Is anything wrong with my code? What am I missing?
#include <16F526.h>
#fuses INTRC_IO, WDT, NOPROTECT, MCLR, IOSCFS_4
#use delay(clock = 4000000, RESTART_WDT)
#use fast_io(B)
#use fast_io(C)
//********************** I/O DEFINITIONS **************************************/
#define startSwitch     PIN_B1
#define floatTop        PIN_B2
#define startLED        PIN_B4
#define drainLED        PIN_B5
#define pumpDrive       PIN_C0
#define valveTop        PIN_C1
#define valveMiddle     PIN_C2
#define floatBottom     PIN_C3
#define floatMiddle     PIN_C4
#define drainSwitch     PIN_C5
INT count=0, STATE;
setup_counters(RTCC_INTERNAL,WDT_1152MS);
set_tris_b(0x0E);                // SET PORT B TO (xxoo iiio) < o= out, i=in
set_tris_c(0x38);                // SET PORT C TO (xxii iooo) < o= out, i=in
SETUP_ADC(ADC_OFF);
SETUP_ADC_PORTS(NO_ANALOGS);
restart_wdt();
//********** INITIALIZATION LED SCAN *****************************************//
// INITIAL POWER UP LED STROBING  //
OUTPUT_LOW(pumpDrive);
OUTPUT_LOW(valveTop);
OUTPUT_LOW(valveMiddle);
OUTPUT_LOW(startLED);
OUTPUT_LOW(drainLED);
restart_wdt();
OUTPUT_HIGH(startLED);
OUTPUT_HIGH(drainLED);
OUTPUT_HIGH(pumpDrive);
OUTPUT_HIGH(valveTop);
OUTPUT_HIGH(valveMiddle);
   while(TRUE) {
      restart_wdt();
PostPosted: Wed Mar 25, 2009 12:26 pm     Reply with quote
Do an experiment. Disable the Watchdog Timer by changing the fuse
to NOWDT. See if that fixes the problem. If so, the problem is related
to the Watchdog Timer.
Also post your compiler version. It's given at the top of the .LST file,
which is in your project directory. It's a 4-digit number in this format:
x.xxx
PostPosted: Wed Mar 25, 2009 12:48 pm     Reply with quote
I tried removing the WDT by adding NOWDT to fuses but it had no effect.
I'm running version 4.089, I believe the latest.
You should also know that I first had a 16F505 running perfectly fine on this same circuit. I swapped out the 'F505 w/ the 'F526 to add the data EEPROM. They're supposed to be pin for pin compatible (f505 > f526).
This is the second 'F526 I used on this board b/c I thought the first one was bad.
Do you want me to post the entire *.lst file?
Oscar
PostPosted: Wed Mar 25, 2009 12:56 pm     Reply with quote
setup_counters() (and setup_wdt() as well) seems to generate incorrect code for the 16F526 (checked with PCB V4.084)
..... setup_counters(RTCC_INTERNAL,WDT_1152MS);
001B:  MOVLW  0E
001C:  MOVWF  07
001D:  CLRF   01
001E:  MOVLW  0F
001F:  OPTION
0020:  CLRWDT
0021:  MOVF   07,W ; reads PORT C state
0022:  OPTION      ; write it to OPTION register
PostPosted: Wed Mar 25, 2009 1:01 pm     Reply with quote
Post your setup_counters() code from the .LST file. We'll compare it
to FvM's code.
In fact, post everything in the .LST file from the start of main(), up to
and including the setup_counters() routine.
orb
PostPosted: Wed Mar 25, 2009 1:12 pm     Reply with quote
Good catch FvM. Here's my complete listing
CCS PCB C Compiler, Version 4.089, 47826               25-Mar-09 13:59
               Filename: F:\OTHER PROJECTS\pelonWaterWorks\FIRMWARE\PELONWATERWORKS.lst
               ROM used: 77 words (8%)
                         Largest free fragment is 512
               RAM used: 5 (20%) at main() level
                         6 (24%) worst case
               Stack:    1 locations
0000:  MOVWF  05
0001:  GOTO   018
0002:  GOTO   003
.................... //                           PELONWATERWORKS.C                                 /
.................... //                           By: Oscar Robles                                  /
.................... //                          Date:  17 FEB 2009                                 /
.................... #include <16F526.h>
.................... //////// Standard Header file for the PIC16F526 device ////////////////
.................... #device PIC16F526
.................... #list
.................... #fuses INTRC_IO, WDT, NOPROTECT, MCLR, IOSCFS_4
.................... #use delay(internal=4M, RESTART_WDT)
0003:  MOVF   0D,W
0004:  BTFSC  03.2
0005:  GOTO   017
0006:  MOVLW  01
0007:  MOVWF  08
0008:  MOVLW  BF
0009:  MOVWF  07
000A:  CLRWDT
000B:  DECFSZ 07,F
000C:  GOTO   00A
000D:  DECFSZ 08,F
000E:  GOTO   008
000F:  MOVLW  4A
0010:  MOVWF  07
0011:  DECFSZ 07,F
0012:  GOTO   011
0013:  NOP
0014:  CLRWDT
0015:  DECFSZ 0D,F
0016:  GOTO   006
0017:  RETLW  00
.................... #use fast_io(B)
.................... #use fast_io(C)
.................... //********************** I/O DEFINITIONS **************************************/
.................... #define startSwitch     PIN_B1
.................... #define floatTop        PIN_B2
.................... #define startLED        PIN_B4
.................... #define drainLED        PIN_B5
.................... #define pumpDrive       PIN_C0
.................... #define valveTop        PIN_C1
.................... #define valveMiddle     PIN_C2
.................... #define floatBottom     PIN_C3
.................... #define floatMiddle     PIN_C4
.................... #define drainSwitch     PIN_C5
.................... //************************ MAIN PROGRAM ***************************************/
.................... void main() {
0018:  CLRF   04
.................... INT count=0, STATE;
0019:  CLRF   0A
.................... setup_counters(RTCC_INTERNAL,WDT_1152MS);
001A:  MOVLW  0E
001B:  MOVWF  07
001C:  CLRF   01
001D:  MOVLW  0F
001E:  OPTION
001F:  CLRWDT
0020:  MOVF   07,W
0021:  OPTION
.................... set_tris_b(0x0E);                // SET PORT B TO (xxoo iiio) < o= out, i=in
0022:  MOVLW  0E
0023:  TRIS   6
.................... set_tris_c(0x38);                // SET PORT C TO (xxii iooo) < o= out, i=in
0024:  MOVLW  38
0025:  TRIS   7
.................... SETUP_ADC(ADC_OFF);
0026:  BCF    09.0
.................... SETUP_ADC_PORTS(NO_ANALOGS);
0027:  BCF    09.6
0028:  BCF    09.7
.................... setup_comparator(NC_NC_NC_NC);
0029:  MOVLW  71
002A:  MOVWF  08
002B:  MOVLW  61
002C:  MOVWF  0B
.................... restart_wdt();
002D:  CLRWDT
.................... //********** INITIALIZATION LED SCAN *****************************************//
.................... // INITIAL POWER UP LED STROBING  //
.................... OUTPUT_LOW(pumpDrive);
002E:  BCF    07.0
.................... OUTPUT_LOW(valveTop);
002F:  BCF    07.1
.................... OUTPUT_LOW(valveMiddle);
0030:  BCF    07.2
.................... OUTPUT_LOW(startLED);
0031:  BCF    06.4
.................... OUTPUT_LOW(drainLED);
0032:  BCF    06.5
.................... delay_ms(500);
0033:  MOVLW  02
0034:  MOVWF  0C
0035:  MOVLW  FA
0036:  MOVWF  0D
0037:  CALL   003
0038:  DECFSZ 0C,F
0039:  GOTO   035
003A:  CLRWDT
.................... OUTPUT_HIGH(startLED);
003B:  BSF    06.4
.................... OUTPUT_HIGH(drainLED);
003C:  BSF    06.5
.................... OUTPUT_HIGH(pumpDrive);
003D:  BSF    07.0
.................... OUTPUT_HIGH(valveTop);
003E:  BSF    07.1
.................... OUTPUT_HIGH(valveMiddle);
003F:  BSF    07.2
0040:  MOVLW  02
0041:  MOVWF  0C
0042:  MOVLW  FA
0043:  MOVWF  0D
0044:  CALL   003
0045:  DECFSZ 0C,F
0046:  GOTO   042
0047:  CLRWDT
0048:  BCF    06.4
0049:  BCF    06.5
004A:  BCF    07.0
004B:  BCF    07.1
004C:  BCF    07.2
....................    while(TRUE) {
004D:  CLRWDT
004E:  GOTO   04D
004F:  SLEEP
Configuration Fuses:
   Word  1: 0FBC   INTRC_IO WDT NOPROTECT MCLR IOSCFS_4 NOCPD
PostPosted: Wed Mar 25, 2009 1:36 pm     Reply with quote
Didn't change to V4.089. You can set WDT related registers manually - or disable WDT til a CCS bug fix.
orb
PostPosted: Thu Mar 26, 2009 6:55 am     Reply with quote
I'm not going to manipulate the hex file in any way. Thanks for the suggestion. CCS will have to fix the bug. I have the feeling that if I change something on my own something else will break.
thanks.
orb
RESOLVED!
PostPosted: Thu Mar 26, 2009 11:32 am     Reply with quote
THANK YOU ALL FOR YOUR HELP, ESPECIALLY VfM.
CCS INC HAS BEEN NOTIFIED OF THE BUG AND A NEW DEVICES DATA FILE HAS BEEN UPDATED.
