sleep and wake up once a second
Ringo42
PostPosted: Wed Mar 25, 2009 7:49 am     Reply with quote
I'm using a pic16f876A and 3.249. Is there a way for the pic to sleep for a certain amount of time then wake up? I see you can wake up from an external event but I want to wake up, check some stuff and go back to sleep.
I'm thinking maybe wake up once a second or so.
Ringo
Ringo Davis
Wayne_
PostPosted: Wed Mar 25, 2009 9:10 am     Reply with quote
You can use the WDT to wake up from sleep.
You can either use the hardware WD which cannot be turned off so you need to kick it while the prog is running and just before going to sleep.
I use the software WD,
turn it on -> sleep -> (WDT) -> wakeup -> turn it off.
Ringo42
PostPosted: Wed Mar 25, 2009 9:13 am     Reply with quote
ok, I know how to set up the watchdog to go off after a second a that will reboot the board, if you are sleeping does it wake you up instead of rebooting, or is there something special to do to wake up instead?
Ringo
Ringo Davis
Wayne_
PostPosted: Wed Mar 25, 2009 10:31 am     Reply with quote
The WDT will wake the pic up from a sleep but reset if the pic was awake Smile
Check the datasheet on the pic you are using. If I remember the info is in there but a bit subtle Smile
Wayne_
PostPosted: Wed Mar 25, 2009 10:34 am     Reply with quote
Page 155, 14.13
"During normal operation, a WDT time-out generates a
device Reset (Watchdog Timer Reset). If the device is
in Sleep mode, a WDT time-out causes the device to
wake-up and continue with normal operation (Watchdog
Timer Wake-up)"
Ringo42
PostPosted: Wed Mar 25, 2009 10:45 am     Reply with quote
Cool, but this looks too easy :-)
Ringo Davis
PostPosted: Wed Mar 25, 2009 1:57 pm     Reply with quote
It is actually easy. Of course the WDT hasn't a precise timing, it's not suitable as a real time clock.
If RTC like precision is required, SEC_IDLE mode with PIC18 can use a watch crystal as time base, but power consumption is considerably higher than with an external RTC chip, that also can provide an 1 Hz wakeup signal.
Ringo42
PostPosted: Wed Mar 25, 2009 1:58 pm     Reply with quote
Thanks, I'm not using it for timing, just power saving so this will be just fine.
Thanks again
Ringo Davis
