PIC12F629 interrupt on change
test153
PostPosted: Tue Mar 24, 2009 2:46 am     Reply with quote
How do I properly enable interrupt on change for GP3 on the 12F629?
ECACE
PostPosted: Tue Mar 24, 2009 11:35 am     Reply with quote
First off, you have to turn off the MCLR function of that pin. This is done in the fuses section. I have ****** next to the line. Next, you enable the interupt for that function. You can't have it interupt just for that pin, it is for the port. But in the ISR, you can just look at the pin you are interested in. See code below:
#include <12F629.h>
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES INTRC                    //Internal RC Osc
#FUSES NOCPD                    //No EE protection
#FUSES NOPROTECT                //Code not protected from reading
#FUSES NOMCLR                   //Master Clear pin used for I/O     *************
#FUSES PUT                      //Power Up Timer
#FUSES BANDGAP_HIGH
#use delay(clock=8000000)
#int_RA
void  RA_isr(void)
   //This will be your port change interupt ISR
   //When a change is detected on Port A you will end up here
   //You will then have to poll Port A to see what changed from the last time youwere here.
   //Then save the current Port settings in a temp var
   //Next time you come in, you compare against that temp var
   //to determine what changed.
   //You can set some flags in the ISR that your main()
   //would look at to see if a change has happened.
   setup_timer_1(T1_DISABLED);
   setup_comparator(NC_NC);
   setup_vref(FALSE);
   enable_interrupts(INT_RA);            //*****It is enabled here*********
   // TODO: USER CODE!!
Good Luck!
A HW Engineer 'trying' to do SW !!! Run!!!
PostPosted: Tue Mar 24, 2009 11:40 am     Reply with quote
Here are some threads on this topic:
http://www.ccsinfo.com/forum/viewtopic.php?t=32702
http://www.ccsinfo.com/forum/viewtopic.php?t=37574
http://www.ccsinfo.com/forum/viewtopic.php?t=25589
test153
PostPosted: Tue Mar 24, 2009 11:55 am     Reply with quote
Would something like
 enable_interrupts(INT_RA3);
work to only enable interrupt on GP3?
PostPosted: Tue Mar 24, 2009 12:05 pm     Reply with quote
Look in the 12F629 data sheet:
http://ww1.microchip.com/downloads/en/DeviceDoc/41190E.pdf
Look in this section:
3.2.2 INTERRUPT-ON-CHANGE
REGISTER 3-4: IOC — INTERRUPT-ON-CHANGE GPIO REGISTER
It shows that individual pins can be enabled/disabled for interrupt on change.
