ds1307+lcd
nina
ds1307+lcd
PostPosted: Mon Mar 23, 2009 6:30 am     Reply with quote
Trying simulate the code below I observe the timer showed on lcd is not the same that from proteus. There is a kind of delay. How can I improve it?
Another problem is when it reach the line
 if ((hora==0x21) && (min==0x15) && (sec==0x03) || status == 0) {
the message blink and I don't want it blink. I want the message TESTING not blink on LCD.
tks
nina
#include <16F877.h>
#include <ds1307.c>
#include <stdio.h>
#include <lcd.c>
byte hora,min,sec;
int status = 1;
init_ds1307();
hora=write_ds1307(2,0x21);
min=write_ds1307(1,0x15);
sec=write_ds1307(0,0x00);
while (1) {
sec=read_ds1307(0);
hora=read_ds1307(2);
min=read_ds1307(1);
lcd_init();
lcd_gotoxy(1,1);
printf(lcd_putc,"Hora: %2X:%2X:%2X",hora,min,sec);
delay_ms(200);
lcd_gotoxy(1,2);
printf(lcd_putc,"TESTING");
delay_ms(200);
status = 0;
PostPosted: Mon Mar 23, 2009 6:52 am     Reply with quote
What do you want to improve? Proteus?
I see that you are continuously re-initializing your LCD display. This can't result in meaningful operation, seriously.
Also your additional text is displayed and then deleted after 200 ms, repeatedly. You simply may want to think about
the intended execution flow of your code and correct it accordingly.
nina
solved
PostPosted: Mon Mar 23, 2009 7:10 am     Reply with quote
Thank you very much FvM
I change the lcd_init() from the while loop to the main() and it worked perfectly.
thank you very much
nina
