Can open ADC port full time?
sorasit46
PostPosted: Tue Mar 17, 2009 5:45 pm     Reply with quote
Hi!
In 16F886, I use ANO & AN4 for capture 2 voltages( 0.2Volts & 1.5 Volts ). Can I turn on ANO & AN4 full time or every time I read ADC I must turn on and turn off. My project read as dynamic data. What way is correct? Now I destroy this port in 2-4 hours.
#include <16F886.h>
#device  ADC=10
#define  CLOCK_SP   4000000
#fuses   hs,NOLVP,WDT,NOPROTECT,NOPUT,NOBROWNOUT,NOCPD,NOWRT,NODEBUG
#use     delay (clock=CLOCK_SP)
#use     fast_io(A)
#use     fast_io(B)
#use     fast_io(C)
#byte    port_b=6
#byte    OSCCON = 0x08F
#ROM 0x2100 = {0x00}
#define  Vbat    PIN_A0            // Input Analog AN0 Leg2,check Battery Voltages.
#define  OverMo  PIN_A5            // Input Analog AN4 Leg7,check motor drive current
#define  Bz      PIN_A3            // Output Buzzer Leg5
#define  Fl      PIN_C4            // Output Flash Leg15
#define  Vbe    0.0048875855327468230694037145650049  // Vcc/ADC10 = (5/1023)
float    Vreadch,Vm_ref
Void     main()
 OSCCON=0x60;
 while ((OSCCON&0x4)!=0x4);
 setup_ccp1(CCP_CAPTURE_FE);                          // Configure CCP1 to capturerise
 setup_ccp2(CCP_OFF);
 enable_interrupts(INT_CCP1);                         // Enable interrupt CCP1
 enable_interrupts(GLOBAL);                           // All interrupts ON
 setup_adc_ports(sAN0 | sAN4);                        // Fix Port AN0 & AN4 for ADC
 setup_adc(adc_clock_internal);
 setup_spi(FALSE);
 enable_interrupts(INT_TIMER0);                       // enable interrupt timer0
 setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);             // setup timer0 enabled
 set_timer0(0);                                       // set timer0
 setup_timer_1(T1_DISABLED);                          // setup timer1 disabled
 setup_timer_2(T2_DISABLED,0,1);                      // setup timer2 disabled
 set_tris_a(0b00110001);
 set_tris_b(0xF8);
 set_tris_c(0b11101101);
 setup_wdt(WDT_2304MS);
 output_low(Bz);output_low(Fl);
       set_adc_channel(0);delay_us(10);               // Read Analog input AN0 (channel=0)
       Vreadch=read_adc();delay_us(10);
       Vreadch =Vreadch*Vbe;
       if (Vreadch < 1.5 ) output_high(Bz);
       Out7seg(Vreadch);                              // LED 7 Segment 3 digits.
       delay_ms(1000);output_low(Bz);restart_wdt();
       set_adc_channel(4);delay_us(10);               // Read Analog input AN4 (channel=4)
       if (Vreadch > 0.2 ) output_high(Fl);
       Out7seg(Vreadch);delay_ms(1000);output_low(Fl);restart_wdt();
[/quote]
OR
[quote]
Void     main()
 setup_adc_ports(NO_ANALOGS);                         // Don't fix port for ADC
 setup_adc(ADC_OFF);                                  // Analog to digital off
       setup_adc_ports(sAN0);setup_adc(adc_clock_internal); // Turn on ADC AN0
       setup_adc_ports(no_analogs);setup_adc(adc_Off); // Don't fix ADC port, ADC off
       setup_adc_ports(sAN4);setup_adc(adc_clock_internal); // Turn on ADC AN4
Regards
sorasit46
PostPosted: Tue Mar 17, 2009 5:59 pm     Reply with quote
Why I can reprogram this destroy chip (verify after programming pass). I use EPIC Version 2.46 Beta. In fact this chip can not use ADC port.
regards
Sydney
PostPosted: Wed Mar 18, 2009 4:51 pm     Reply with quote
You dont need to turn it off, but you need to read the datasheet as you are using adc_clock_internal, which you shouldnt be.
