Kurt Franke Guest
stack undeflow on 18F452, example included |
Posted: Tue Dec 17, 2002 11:48 am |
I traced an intermittant reset in my application to a
relatively simple line of math. Below I have included
a sample program with illustrates this. It causes a
stack underflow when simulated in MPLAB and continually
resets when running on my hardware at the line
g = f - ADC_TO_U(b>>4);
Has anyone else seen anything like this before?
I have tested this with PCW 3.129 (current version).
Any help greatly appreciated. I will send this to CCS also.
--- test.c
#include <18F452.h>
#include <math.h>
// SET CLOCK FOR WHATEVER YOU HAVE
#use delay (clock = XXXXXXX)
#fuses HS, NOPROTECT, NOWDT, PUT, NOBROWNOUT, NOLVP
#use rs232 (baud=9600, xmit=PIN_C6, rcv=PIN_C7)
//#define DEBUG printf // use to print messages
#define DEBUG // use to skip messages
#define OFFSET (50)
#define ADC_TO_U(x) (((x) <= OFFSET)? 0.0 : sqrt((float)((x)-OFFSET)))
void main() {
int16 a,b;
float f,g;
DEBUG ("Starting : cause 0x\%x\r\n", restart_cause());
a = 815;
b = 815;
DEBUG ("a = \%lu\r\n", a);
DEBUG ("b = \%lu\r\n", b);
f = ADC_TO_U(a>>4);
DEBUG ("got f\r\n");
DEBUG ("f = \%f\r\n", f);
g = f - ADC_TO_U(b>>4); // CRASH!
DEBUG ("got g\r\n");
DEBUG ("g = \%f\r\n", g);
while (1);
___________________________
Original Post ID: 10094 |
chas Guest
Re: stack undeflow on 18F452, example included |
Posted: Tue Dec 17, 2002 1:02 pm |
:=I traced an intermittant reset in my application to a
:=relatively simple line of math. Below I have included
:=a sample program with illustrates this. It causes a
:=stack underflow when simulated in MPLAB and continually
:=resets when running on my hardware at the line
:= g = f - ADC_TO_U(b>>4);
:=Has anyone else seen anything like this before?
:=I have tested this with PCW 3.129 (current version).
:=Any help greatly appreciated. I will send this to CCS also.
:=--- test.c
:=#include <18F452.h>
:=#include <math.h>
:=// SET CLOCK FOR WHATEVER YOU HAVE
:=#use delay (clock = XXXXXXX)
:=#fuses HS, NOPROTECT, NOWDT, PUT, NOBROWNOUT, NOLVP
:=#use rs232 (baud=9600, xmit=PIN_C6, rcv=PIN_C7)
:=//#define DEBUG printf // use to print messages
:=#define DEBUG // use to skip messages
:=#define OFFSET (50)
:=#define ADC_TO_U(x) (((x) <= OFFSET)? 0.0 : sqrt((float)((x)-OFFSET)))
:=void main() {
:= int16 a,b;
:= float f,g;
:= DEBUG ("Starting : cause 0x\%x\r\n", restart_cause());
:= a = 815;
:= b = 815;
:= DEBUG ("a = \%lu\r\n", a);
:= DEBUG ("b = \%lu\r\n", b);
:= f = ADC_TO_U(a>>4);
:= DEBUG ("got f\r\n");
:= DEBUG ("f = \%f\r\n", f);
:= g = f - ADC_TO_U(b>>4); // CRASH!
:= DEBUG ("got g\r\n");
:= DEBUG ("g = \%f\r\n", g);
:= while (1);
I'm wondering if your #define OFFSET (50) is defaulting to an int and causing problems. Try changing the define to #define OFFSET (int16)(50) and see if it helps.
Original Post ID: 10098 |
Kurt Franke Guest
further investigations... |
Posted: Tue Dec 17, 2002 2:17 pm |
Here's a simpler program:
#include <18F452.h>
#nolist
#include <math.h>
#list
#define OFFSET ((int16)(50))
#define ADC_TO_U(x) (((x) <= OFFSET)? 0.0 : 2.0)
void main() {
int16 a,b;
float f,g;
a = 815;
b = 815;
f = ADC_TO_U(a>>4);
while (1);
This program goes into an infinite loop (I mean, before the
while(1) statement).
Looking at the listing there is a bad goto statement in the
g= line that jumps back into the middle of the f= line.
OK. Now things get very weird because if you don't include
math.h, this program seems to work. Huh??
(Listing of assembly of g= line with bad goto statement marked)
.................... g = f - ADC_TO_U(b>>4);
03A0: RRCF 09,W
03A2: MOVWF 13
03A4: RRCF 08,W
03A6: MOVWF 12
03A8: RRCF 13,F
03AA: RRCF 12,F
03AC: RRCF 13,F
03AE: RRCF 12,F
03B0: RRCF 13,F
03B2: RRCF 12,F
03B4: MOVLW 0F
03B6: ANDWF 13,F
03B8: BTFSS FD8.2
03BA: GOTO 03D4
03BE: MOVF 12,W
03C0: SUBLW 32
03C2: BTFSS FD8.0
03C4: GOTO 03D4
03C8: CLRF 00
03CA: CLRF 01
03CC: CLRF 02
03CE: CLRF 03
03D0: GOTO 0370 <---- 370 is in the middle of the previous c statement.
03D4: MOVLW 80
03D6: MOVWF 00
03D8: CLRF 01
03DA: CLRF 02
03DC: CLRF 03
03DE: BSF FD8.0
03E0: MOVFF 0D,17
03E4: MOVFF 0C,16
03E8: MOVFF 0B,15
03EC: MOVFF 0A,14
03F0: MOVFF 03,1B
03F4: MOVFF 02,1A
03F8: MOVFF 01,19
03FC: MOVFF 00,18
0400: GOTO 0004
0404: MOVFF 03,11
0408: MOVFF 02,10
040C: MOVFF 01,0F
0410: MOVFF 00,0E
Original Post ID: 10102 |
Kurt Franke Guest
Posted: Tue Dec 17, 2002 5:24 pm |
:=I'm wondering if your #define OFFSET (50) is defaulting to an int and causing problems. Try changing the define to #define OFFSET (int16)(50) and see if it helps.
Nope, doesn't seem to change anything.
-Kurt
Original Post ID: 10105 |
chas Guest
Posted: Wed Dec 18, 2002 11:20 am |
:=:=I'm wondering if your #define OFFSET (50) is defaulting to an int and causing problems. Try changing the define to #define OFFSET (int16)(50) and see if it helps.
:=Nope, doesn't seem to change anything.
:=-Kurt
Kurt,
I tried it and several other permutations, and got the same results as you. It didn't work (strange goto) with the math.h included, even though no calls to math.h functions were used in the simple program. But it did work without the math.h included. Very strange!?!
The next thing to try might be ditching the macro and rewriting as a function.
-chas
Original Post ID: 10122 |
chas Guest
Posted: Wed Dec 18, 2002 8:45 pm |
:=-Kurt
Try this and see if it works:
#include <18F452.h>
#include <math.h>
// #define ADC_TO_U(x) (float)(((x) <= OFFSET)? 0.0 : 2.0)
float ADC_TO_U(int16 x)
if (x <= OFFSET)
return 0.0;
return 2.0;
void main() {
int16 a,b;
float f,g;
a = 815;
b = 815;
f = ADC_TO_U(a>>4);
while (1);
Original Post ID: 10130 |
Kurt Franke Guest
Posted: Thu Dec 19, 2002 8:50 am |
:=Try this and see if it works:
:= (my macro converted to function using if/else instead of ?:)
I'm pretty certain this will work. CCS told me the problem
was arose from using a conditional inside a larger expression.
I changed the g = line to:
temp = ADC_TO_U(b);
g = f-temp;
and this works.
.. Unfortunately I am now having a different problem elsewhere
(more on this later)
Thanks for taking a look at this chas,
--Kurt
Original Post ID: 10138 |
