P18 and VS1002D mp3 decoder
electrogen
PostPosted: Wed Mar 18, 2009 1:21 am     Reply with quote
While I'm trying to make a hard reset to the VS1002d,
it never raise its DREQ line so that I may feed it with mp3 data and all the program stuck there. Here is my code
/* PIC18F458 running at 20MHz
    xreset ->pic pin C1  o/p--->VS reset
    xdreq<--pic pin A4   i/p----<VS DREQ
    xcs    -->pic pin E2   o/p--->VS xCS
    xdcs  -->pic pin A5   o/p--->VS xDCS
void resetvs_hard(void)
  output_high(xcs);output_high(xdcs);
  do
    output_low(xreset);                  //hard reset
    delay_cycles(250);
    output_high(xreset);
    delay_cycles(650);
    delay_cycles(600);
    vs_command(0x02,0x00,0x00,0x04);     //sets new mode (native SCI mode) and reset bit
   }while(!input(xdreq));                //stuck here(xdreq is always down)
   delay_ms(1);
   vs_command(0x02,0x00,0x08,0x00);      //go into new mode (native SCI mode)
   delay_ms(1);
   vs_command(0x02,0x03,0x30,0xD4);      //clock =25MHz
   delay_ms(1);
   vs_command(0x02,0x0B,volume,volume);  //set volume
   delay_ms(1);
and also draws much current (800mA) when it performs this function. What possibly be wrong with it?
FYI: the MP3 is one feature in my system; everything else is working fine
