16f877a internal eeprom problem???
slsslssls
PostPosted: Tue Mar 17, 2009 10:00 am     Reply with quote
hi,
I am trying to use internal eeprom on 16f877a. There is no problem on proteus, but my circuit is not working true.
Data that I wrote on eeprom is being erased when power off.
How can this be?
PostPosted: Tue Mar 17, 2009 10:17 am     Reply with quote
How do you know it's not working correctly? Is the rest of your hardware working?
Post some complete sample code, and your compiler version.
Jeff
slsslssls
PostPosted: Tue Mar 17, 2009 10:30 am     Reply with quote
For example,
When I compile this code:
write_eeprom(1,'2');
lcd_putc(read_eeprom(1));
I can see 2 on LCD.
Then I erase -- write_eeprom(1,'2') -- and I can't see 2 on display.
I had written to eeprom '2'. How can it be erased?? I can't understand this. I couldn't solve the problem. :(
PostPosted: Tue Mar 17, 2009 10:54 am     Reply with quote
If you erased "write_eeprom(1,'2')", then presumably you _erased_, and reprogrammed the chip. EEPROM will be erased as well, unless you tell your programmer not to do this...
slsslssls
PostPosted: Tue Mar 17, 2009 10:59 am     Reply with quote
How can I tell the programmer not to do this??
slsslssls
PostPosted: Tue Mar 17, 2009 12:52 pm     Reply with quote
Now, there is no problem! SmileSmile
