info@ckmintech.com
12f675 ADC |
Posted: Sun Mar 15, 2009 9:17 am |
I need to have a program to read a ADC value from AN1. The following is part of my program and it works.
#include <12f675.h>
#device adc=8
main()
int advValue;
setup_adc_ports(sAN1|VSS_VDD);
set_adc_channel(1);
delay_us(10);
adcValue=read_adc();
The adcValue read is around 100 (this is correct)
I need to implement a software RS232 without MAX232 chip and added
Code: | #use rs232(baud=9600,parity=N,xmit=PIN_A4,rcv=PIN_A2,bits=8, INVERT, stream=RS232IN) |
after #device adc = 8
When I hook up the RS232 connection, the adcValue changed to 18
It seems that it is reporting the value is not in the range VSS_VDD.
I added
setup_vref( FALSE ); |
but the result is the same.
Any idea how to correct the problem?
Rgds. |
Posted: Sun Mar 15, 2009 1:00 pm |
Post a complete test program. Take the code that you posted, and
add the #fuses, #use delay(), and #use rs232() statements to it.
Add a printf statement that displays the ADC value.
Add a while(1); statement at the end of the program.
Add a few lines of code to make it into a complete test program
that is compilable.
Post your compiler version. |
info@ckmintech.com
Posted: Sun Mar 15, 2009 6:21 pm |
Code: | #include <12f675.h>
#device adc=8
#FUSES NOWDT
#FUSES INTRC_IO, PROTECT
#use rs2232(baud=9600,parity=N,xmit=PIN_A0,rcv=PIN_A5,bits=8,stream=outdata)
main()
int adcValue;
set_adc_channel(1);
while (true) {
delay_ms(1);
fprintf(outdata,"(%d)", adcValue );
The reading is around 20 (not correct). After I cut the connection DB9 pin 3, the value came back to normal - 100
Complier is OCH 3.249
Rgds. |
Posted: Sun Mar 15, 2009 10:12 pm |
Quote: | I need to implement a software RS232 without MAX232 chip and added
After I cut the connection DB9 pin 3, the value came back to normal - 100.
Do you have a series resistor between pin 3 of the Com1 connector
on your PC, and pin A2 on the PIC ? You need one. Normally, a 22K
ohm resistor is used with this type of direct connection. You only need
a resistor between the Tx pin of Com1 on the PC (pin 3) and the Rx pin
on the PIC. Without that resistor, you are putting -10v at 20ma
(or more) on pin A2 of the PIC. That could be the cause of your problems. |
Posted: Mon Mar 16, 2009 2:04 am |
Yes. I have a 47K resistor.
Rgds. |
Posted: Mon Mar 16, 2009 2:14 am |
1. What is the Vdd voltage for your PIC ?
2. What are you using for a power supply for the 12F675 ? Is it a voltage
regulator ?
3. Do you have a pull-up resistor on the MCLR pin ? What value is it ?
4. Why do you have the PROTECT fuse enabled for this project ? |
Posted: Mon Mar 16, 2009 7:15 am |
1. Vdd is +5V
2. The power is stealed from Pin 4 and Pin 7 of the RS232 by using 1N4148 diode as an input for 78L05 regulator. The output of the 78L05 regulator will power up the circuit
3. a 10K pullup for MCLR
4. PROTECT is our my standard fuse
Rgds. |
Posted: Mon Mar 16, 2009 12:22 pm |
I can't find my 12F675 right now. If I find it later, I'll test your code.
When I test it, I will use a bench power supply, and not serial port power.
I also will use a Max232A chip instead of INVERT mode. And I will not
use the PROTECT fuse. If it doesn't work, I will install a 4 MHz crystal,
instead of the internal oscillator.
In other words, I will do whatever it takes to make it work, by using
standard methods, rather than trying to "push" every aspect of the
design. |
