SPI bus as a slave on the PIC chip
abq_guy
PostPosted: Fri Mar 13, 2009 10:13 am     Reply with quote
I am using the PIC18F8722. It is connected to an FPGA on one of the SPI bus and to a DAC and ADC on the other SPI bus. The SPI bus connected to the DAC and ADC will be configured as a MASTER, whereas the SPI bus connected to the FPGA is configured as a SLAVE.
The FPGA will initiate requests for setting the voltage on the DAC and reading back from the ADC.
In the Slave mode, the PIC cannot initiate the data transfer to the FPGA. My question is that how will it send the ADC data to the FPGA if it cannot initiate them ?
Also I want to read the data every 100ms from the ADC.
The user can also set the DAC at anytime he wishes. If the data from the ADC is being read while the user wants to set the voltage on the DAC, will it cause collisions on the SPI bus ?
This is more of an system architecture problem. Please elaborate.
Thanks,
abq_guy
PostPosted: Fri Mar 13, 2009 10:19 am     Reply with quote
The first part is down to you designing a signal. Typically, use an output line that signals the master device to say that the slave has data ready, and triggers it to initiate a transaction.
The second, is down to using buffering. Obviously there can only be one transaction on the bus at a time, but the speed of a typical SPI transaction, will be a few uSec. You buffer the request to set the DAC, and send it as soon as the ADC reading has completed. A delay of a few uSec.
abq_guy
PostPosted: Fri Mar 13, 2009 10:31 am     Reply with quote
I like your idea of using a spare line to signal to the master that the ADC data is ready for it to initiate the transmission.
I read somewhere that the SPI bus is a full duplex bus.
So if that is the case, it should be similar in functionality to the UART except that there is a Master - slave concept.
IF there is a request from the user to set the DAC, that request is send on the MOSI line, whereas the ADC data from the PIC chip comes to the FPGA on the MISO line.
Will the FPGA still need to buffer the request ?
The FPGA can send the request for ADC readings every 100ms, and the DAC voltage setpoints whenever the user desires, except the time its already sending the request for ADC readings. It will need to buffer the DAC request, if the DAC request falls in the same time frame as the ADC request.
Also what happens to the SPI bus which has been configured to be the MASTER for the DAC and the ADC ?
Will it behave almost similarly to the SPI bus that has been configured as a SLAVE ?
Thanks,
abq_guy
PostPosted: Fri Mar 13, 2009 3:40 pm     Reply with quote
SPI, is full duplex. Data is transferred both ways at the same time. _But_ unlike RS232, one device has to control all transactions (establishing the clock). This is the master.
It is the PIC (the master for the two external devices), that will have to buffer the DAC value. These devices will presumably have slave select lines implemented (will be needed to say which device to talk to), and if the master is talking to the ADC, it'll have to complete these transaction, _then_ deselect this chip, and select the other, then send the DAC request.
Only masters can initiates transactions (start the clock).
If a user is sending a request, who is generating the clock (FPGA?). If so, how is this told to do so?. If the FPGA is the master, then it'll control the timings, and access. If it has more than one device on any single bus, and their operation is asynchronous to each other, then there either has to be buffering fo the requests, or the one request has to be delayed till the bus is clear.
You really can't transfer data from different devices at the same time. Each device will require a 'frame' of some form (select line dropping, command being sent, reply etc.), and to have another device sending data at the same time, and not leading to conflicts, would require complete control of the nature of the packets, getting them to be the same size etc., and triggering the transfers using the same control (or sync can be lost).
SPI, is full duplex, but is 'point to point' only one pair of devices talking at any one time.
