I'm new to CCS. June 2008 manual indicates multiple compilation units are demonstrated in MCV.ZIP but I havent been able to find it.
I'm used to mcc18 where makefile functionality is transparent and I am used to breaking up project into 'object' like modules. I'll re-learn the art of makefiles if I can find out the necessary keywords and syntax used by CCS. _________________ Pc
Posted: Thu Jul 24, 2008 11:51 pm
Open a Dos box and go to the examples directory. Do a dir *.zip.
You will quickly find: MCU.zip
Posted: Fri Jul 25, 2008 12:11 am
I'm guessing your directing me to a folder that was loaded when the compiler was installed (I'm on WinXP). I'll check if it exists when I get on my work computer. I was expecting to be able to download from CCS site but havent a clue how I could do that via a DOS box.
Thanks for the reply
pc
Posted: Fri Jul 25, 2008 12:16 am
It's on your system:
c:\Program Files\PICC\Examples\mcu.zip
cerberus Guest
mcv.zip where are you?
Posted: Thu Mar 12, 2009 8:44 am
CCS didn't include mcu.zip until version 4.033. I have version 4.018 where the maintenance has expired and so I can't update to a later version. Can someone post the mcu.zip file? It would be greatly appreciated.
Heath
Posted: Thu Mar 12, 2009 9:40 am
I don't think that is allowed. Contact CCS support for the file.
