Define and asm code
Franck26
Define and asm code
PostPosted: Tue Mar 10, 2009 9:24 am     Reply with quote
To optimize a code I try to implement this define:
#define   SetEvent(x,y)   #if y<8   #asm BSF x,y #endasm   #else #asm BSF x+1,(y-8) #endasm #endif
x is an int16 variable and y a constant (0 to 15).
What I want to do is to set the bit y of the variable x.
I've got the error "Expecting an opcode mnemonic" if y>7.
unsigned int16 TEST_Event;
TEST_Event = 0;
SetEvent(TEST_Event, 2);   // OK
SetEvent(TEST_Event, 10);   // Error: Expecting an opcode mnemonic
Do you have any idea how to implement this define?
Thanks for any help,
Franck.
Compiler CCS 4.083.
Sydney
PostPosted: Tue Mar 10, 2009 11:10 am     Reply with quote
Am I missing something, or are you?
TEST_Event = 0;
bit_set(TEST_Event, 2);   // OK
bit_set(TEST_Event, 10);   // OK
Sydney
PostPosted: Tue Mar 10, 2009 11:13 am     Reply with quote
.................... unsigned int16 TEST_Event;
.................... TEST_Event = 0;
2002:  CLRF   xC6
2004:  CLRF   xC5
.................... bit_set(TEST_Event, 2);   // OK
2006:  BSF    xC5.2
.................... bit_set(TEST_Event, 10);   // OK
2008:  BSF    xC6.2
RLScott
Re: Define and asm code
There is no reason to mess around with that macro. Just use:
  bit_set(TEST_Event,2);
  bit_set(TEST_Event,10);
The compiler is smart enough to convert each of these to the one instruction that your macro was trying to do. Try it and look at the resulting .LST file to see what I mean.
Ha, Sydney, you beat me to it!
Robert Scott
Real-Time Specialties
Embedded Systems Consulting
Franck26
PostPosted: Tue Mar 10, 2009 12:08 pm     Reply with quote
Thanks for your answer,
It's true that it's the easiest way to do it...
I've just forgot to precise that I would like to keep the code compatible with other PIC compiler than CCS. I should have say that earlier...
Other idea?
Thanks for your help.
FvM
PostPosted: Tue Mar 10, 2009 12:16 pm     Reply with quote
In this case you can use bit_set() in your macro for CCS with a version dependant conditional compile.
The capabilities of CCS C to understand certain asm constructs seems somewhat arbitrary, B.T.W.
Sydney
PostPosted: Tue Mar 10, 2009 12:18 pm     Reply with quote
1FA4:  CLRF   xC6
1FA6:  CLRF   xC5
.................... TEST_Event |= 1 << 2;   // OK
1FA8:  BSF    xC5.2
.................... TEST_Event |= 1 << 10;   // OK
1FAA:  BSF    xC6.2
Franck26
PostPosted: Wed Mar 11, 2009 5:19 am     Reply with quote
OK, I'll make a conditional compile dependent on the version.
That's pity that
is not understood by CCS, it would be cleaner and portable Sad ...
Thanks for your help,
Franck.
PostPosted: Wed Mar 11, 2009 8:37 am     Reply with quote
The 'x+1' syntax, would not be understood by CCS anyway.
Assembler like this, is never going to be 'portable'. CCS uses CCS assembler, Microchip, use Microchip assembler, HiTech, use HiTech assembler. etc.. All have differences.
CCS, treats the name of a variable in assembler, as if it is the address of the variable, and allows the 'shortcut', of using the name as a target. To address the next byte, the syntax is actually &x+1. If you try the two assembler lines without the if statement, this is the syntax needed to make the second one work.
Moving between any language, is going to require different syntaxes. If you want to write this as a 'portable construct', then have a define at the start of your code, saying what complier you are working on, and a include file containing the different defines to work for the various compilers so something like:
#ifdef CCS
   #define SetEvent(x,y) bit_set(x,y)
#elif MicroChip
   #define   SetEvent(x,y)   #if y<8   #asm BSF x,y #endasm\
#endif
You will have to do a lot of syntax tweaking though, including redefining the variable name/sizes etc..
Sydney
PostPosted: Wed Mar 11, 2009 1:44 pm     Reply with quote
What was the matter with my method, will work on any c compiler? :(
Franck26
PostPosted: Wed Mar 11, 2009 3:22 pm     Reply with quote
Hello Sydney,
Your method would work with any C compiler but it's not sure that it would be optimised.
The compiler could generate a loop to shift a mask and it would increase the executive time.
Your test show that CCS compiler is enough clever to avoid that Very Happy .
Franck.
Sydney
PostPosted: Wed Mar 11, 2009 3:44 pm     Reply with quote
True, I was suprised it did compile to 2 instruction actually Smile
