PIC18F8723 Setup
Armer175
PIC18F8723 Setup
PostPosted: Tue Mar 10, 2009 10:07 am     Reply with quote
OK, I am starting a new project. I will be using two different SPI device on SPI2 and I2C device(which is on SPI1 PINs). I also will be reading in data from GPS (UART1) and using UART2 as a debug output. I have two analog inputs and then a few digital I/O.
I decide to make sure each device seperately is working so I will know if my problem is in the code or the interface.
I am trying to print out "hello world" through the first uart but it is not working. I hook up the second uart and it is working. When I use a printf statement I do I tell it what UART to use? Here is my code sofar.
.H File:
#include <18F8723.h>
//#device ICD=TRUE
#device adc=12
#FUSES INTRC                    //Internal Osc
#FUSES BORV25                   //Brownout reset at 2.5V
#FUSES NOPUT                    //No Power Up Timer
//#FUSES NODEBUG                  //No Debug mode for ICD
#FUSES NOCPB                    //No Boot Block code protection
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES NOFCMEN                  //Fail-safe clock monitor disabled
#FUSES LPT1OSC                  //Timer1 configured for low-power operation
#FUSES MCLR                     //Master Clear pin enabled
#FUSES MCU                      //Microcontroller Mode
#FUSES NOWAIT                   //Wait selections unavailable for Table Reads or Table Writes
#FUSES BW16                     //16-bit external bus mode
#FUSES ABW16                    //16-bit Address bus
#FUSES ECCPE                    //Enhanced CCP PWM outpts multiplexed with RE6 thorugh RE3
#use delay(clock=8000000)
//#define I2C_SCL   PIN_C3
//#define I2C_SDA   PIN_C4
//#define TX1   PIN_C6
//#define RX1   PIN_C7
//#define SPI2_SCK2   PIN_D6
//#define TX2   PIN_G1
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,UART1)
#use rs232(baud=9600,parity=N,xmit=PIN_G1,rcv=PIN_G2,bits=8,UART2)
#use i2c(Master,Fast,sda=PIN_C4,scl=PIN_C3,force_hw)
Main Program:
  #include   <header>                       //I  use the full pathname in actual program
  #include <float.h>
  #include <math.h>
  #include <stdio.h>
  #include <string.h>
#define SPI_MODE_0  (SPI_L_TO_H | SPI_XMIT_L_TO_H)
#define SPI_MODE_1  (SPI_L_TO_H)
#define SPI_MODE_2  (SPI_H_TO_L)
#define SPI_MODE_3  (SPI_H_TO_L | SPI_XMIT_L_TO_H)
   setup_psp(PSP_DISABLED);
   setup_spi2(SPI_MASTER|SPI_MODE_3|SPI_CLK_DIV_16);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   setup_oscillator(OSC_8MHZ|OSC_INTRC|OSC_31250|OSC_PLL_OFF);
   Output_High(PIN_E7);
   While(1)
Output_Low(PIN_E7);
Spi_Write2(0x20);
delay_us(1);
   printf("Hello World\r\n");
PostPosted: Tue Mar 10, 2009 10:21 am     Reply with quote
Do all RS-232 operations with "streams". Use the CCS stream functions
for this. Use fprintf() instead of printf(). Use fputc() instead of putc(),
etc. In each of those functions you specify the stream that is used.
See the manual for more information.
PICoHolic
PostPosted: Tue Mar 10, 2009 10:28 am     Reply with quote
for ex:
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8, STREAM = S1, UART1)
#use rs232(baud=9600,parity=N,xmit=PIN_G1,rcv=PIN_G2,bits=8, STREAM = S2,  UART2)
putc(data, S2);   //or fputc
fprintf(S1, "hello world");
Armer175
PostPosted: Tue Mar 10, 2009 10:33 am     Reply with quote
Thanks works great now! Very Happy
Armer175
PostPosted: Tue Mar 10, 2009 12:02 pm     Reply with quote
#define SD21 0xC2 // SD21 I2C Address
int16 servo1;
int8 servo1LowByte;
int8 servo1HighByte;
int8 Speed;
setup_wdt(WDT_OFF);
setup_vref(FALSE);
setup_oscillator(OSC_4MHZ|OSC_INTRC|OSC_31250|OSC_PLL_OFF);
Speed = 0;
servo1=1500; // For Parallax servo 2200-500 center at 1400
servo1LowByte = make8(servo1, 0);
servo1HighByte = make8(servo1, 1);
While(1)
//Output_Low(PIN_E7);
//Spi_Write2(0x20);
//Output_High(PIN_E7);
//delay_us(1);
//fprintf(UART1,"Hello World\r\n");
i2c_start();
i2c_write(SD21);
i2c_write(0x00); // send register address
i2c_write(Speed); // send the data
i2c_write(servo1LowByte); // send the data
i2c_write(servo1HighByte); // send the data
i2c_stop();
PostPosted: Tue Mar 10, 2009 12:22 pm     Reply with quote
CCS combines the 7-bit i2c slave address and the R/W bit into one byte.
So in the CCS world, the slave address is shifted to left by one bit.
In the Philips world, an i2c slave address consists of 7 bits, and is not
shifted. It's right justified.
This is entirely an issue of representation, and manner of thinking.
It could also be an issue of interpretation by your logic analyzer's
protocol analyzer. An i2c slave address of 0x61 in Philips format, is
0xC2 in CCS format.
Armer175
PostPosted: Tue Mar 10, 2009 7:33 pm     Reply with quote
I did connect some servos to the controller later and it was working correctly. Just goes along with what you were saying about the W/R bit. Thanks again PCM Programmer Smile
Armer175
New Problem
PostPosted: Wed Mar 11, 2009 12:47 pm     Reply with quote
I am now having some problems reading from the spi device(ADIS16350)
datasheet:
http://www.analog.com/static/imported-files/data_sheets/ADIS16350_16355.pdf
I want to read in the "supply out" out register (pg14). But Iam not getting correct data out. I dont think i am reading the register correctly. PLEASE Help.
 While(1)
Output_Low(PIN_E7);
Spi_Write2(0x03);                                //send out address to read from
SUPPLY_OUT_HIGH=SPI_READ2(0);      //read highbyte
//DELAY_MS(10);
Output_Low(PIN_E7);
Spi_Write2(0x02);
SUPPLY_OUT_LOW=SPI_READ2(0);      //read lowbyte
SUPPLY_OUT=MAKE16(SUPPLY_OUT_HIGH, SUPPLY_OUT_LOW);     //combine highbyte and lowbyte
BIT_CLEAR(SUPPLY_OUT,15&14&13&12);    //cleart top bits that are not needed.
voltage=SUPPLY_OUT*1.8315e-3;   //calculate voltage
 fprintf(UART1,"total %lx voltage %2.5f \r\n",SUPPLY_OUT, voltage);
   //servocontrol();
  DELAY_MS(1000);
Confused
PostPosted: Wed Mar 11, 2009 2:09 pm     Reply with quote
You need to write a driver for the ADIS16350 chip.
It needs to be written as a separate file, named ADIS16350.c.
It should have functions to read and write to the chip.
You need to try to write the ADIS16350 driver by yourself,
and if you have problems then start a new thread about it.
Here is a thread on another ADIS chip, where I have explained how
to setup the correct SPI mode.
http://www.ccsinfo.com/forum/viewtopic.php?t=38016&start=5
Do not add your questions onto that thread.
Look at this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=38131
Notice my suggestions on how to clean up the code.
This is an invention by you. Never do this. We will spot it immediately.
The CCS manual says you may use a single number, from 0 to 31
for that parameter. It's just wasting our time if you invent things.
bit_clear( )
Syntax: bit_clear(var, bit)
Parameters: var may be a any bit variable (any lvalue)
bit is a number 0-31 representing a bit number, 0 is the least significant bit.
Don't use ALL CAPS for functions and variables. It's not the C standard.
Use lower case or mixed case.
Armer175
PostPosted: Wed Mar 11, 2009 3:22 pm     Reply with quote
Is there an advantage to using a driver file other than making the main look cleaner? I was going to create seperate functions outside the main.
I haven't programmed in C for a long time so its been rough trying to write nice code. Thanks again for your help!
PostPosted: Wed Mar 11, 2009 3:51 pm     Reply with quote
The driver file allows you to create your own personal library of known-
good, working drivers. You can just "drop" the driver into a new project
(with an #include statement) and you know it works.
