Multiple Files in Project
solarwind
PostPosted: Sun Mar 08, 2009 11:30 pm     Reply with quote
How does one add multiple C and H files to a project? I want to organize my source code into groups. For example, I have a main.c file and in there I want to include my driver which consists of driver.c and driver.h. Normally, one would include driver.h but all the examples I've seen are always including the c file which is considered very poor programming practice.
How do I add driver.c and driver.h into the project so I may #include driver.h in my main file?
http://solar-blogg.blogspot.com
PostPosted: Mon Mar 09, 2009 12:46 am     Reply with quote
Use the search page. Search for:
Multiple files
There are many threads on the topic:
http://www.ccsinfo.com/forum/viewtopic.php?p=110805
solarwind
PostPosted: Mon Mar 09, 2009 1:45 pm     Reply with quote
Multiple files
Yes, that would be the obvious thing to do. I would not have posted if I had not already searched and found results.
PostPosted: Mon Mar 09, 2009 1:50 pm     Reply with quote
If you have the IDE version of the CCS compiler, then you can use
"Multiple Compilation Units":
http://www.ccsinfo.com/content.php?page=ideoverview#multiple
If you're using a CCS command line compiler with MPLAB, then you need
to do it as described in the link that I posted.
