Timer2 calculate...
Timer2 calculate...
PostPosted: Fri Mar 06, 2009 12:09 pm     Reply with quote
Hi
Is this right?
Ask because the timer make interrupt every 5,7ms and i expect 5ms.
The measurement is done with a logic analyzer.
CPU is running 8mhz.
PIC is 18xx2455.
Config timer:
setup_timer_2(T2_DIV_BY_16,78,8); //8 bit 1/8mhz*4 * 16*78*8=5ms
Reload at the interrupt.
set_timer2(0xff-78);
PostPosted: Fri Mar 06, 2009 2:34 pm     Reply with quote
This test program gives me an interrupt every 4.99 ms.
#include <18F452.h>
#fuses HS,NOWDT,PUT,BROWNOUT,NOLVP
#use delay(clock=8000000)
#int_timer2
void timer2_isr(void)
output_toggle(PIN_B0);
output_low(PIN_B0);
setup_timer_2(T2_DIV_BY_16, 77, 8);
clear_interrupt(INT_TIMER2);
PostPosted: Fri Mar 06, 2009 3:59 pm     Reply with quote
Two things apply.
First, the timer counts to the loaded value +1. For 78 counts, you need to load 77 as PCM programmer shows.
Second, is that the whole point of timer2, is that it resets _itself_ when it gets to the preset count. What you are doing, is that it gets to 78, resets itself to zero, and calls the interrupt handler. At this point, about 20uSec latter, inside the interrupt routine, you are loading it again, and by yet another count to much (value would want to be 0-77).
So your timings, will be long by two extra counts, and the time taken to get into the interrupt handler....
PCM, shows how to use this.
PostPosted: Fri Mar 06, 2009 5:21 pm     Reply with quote
Hi
1000*thanks:-)
I misunderstand timer2. I use timer2 as timer1, and make the reload myself. And I used it as rolling round at ff+1 as timer1!
Sydney
PostPosted: Sat Mar 07, 2009 2:49 am     Reply with quote
setup_timer_2(T2_DIV_BY_4, 249, 10); // 1/8000000*4*4*250*10=5.000ms
Not much in it but is slightly closer than yours if timing is an issue Smile
