newbies in C language
sunny
PostPosted: Fri Feb 27, 2009 9:15 pm     Reply with quote
hi everyone...
i am really new in this stuff..i need to compare two set of voltage using pic 16f877A..how do i achieve this...
IceMetal
PostPosted: Fri Feb 27, 2009 9:45 pm     Reply with quote
you will need to start looking at ADC samples, whats the voltage range that you have?
sunny
PostPosted: Fri Feb 27, 2009 10:15 pm     Reply with quote
my voltage range is between 5V to 25V..thanks..i should try...
sunny
PostPosted: Tue Mar 03, 2009 2:14 am     Reply with quote
This is my code. How can I refer to reference voltage and compare it with input voltage ? Does it have special code or something ?
#if defined(__PCM__)
#include <16F877.h>
#elif defined(__PCH__)
#include <18F452.h>
#define LED pin_A5
   int ref,voltage;
   setup_port_a( RA0_RA1_ANALOG_RA3_REF );
   setup_adc( ADC_CLOCK_INTERNAL );
   set_adc_channel( 0 );
   ref=5;
   while(true){
   voltage=read_adc();
    if(voltage>ref){
    output_high(LED);
