andreluizeng
| SD Card Initialization problem |
Posted: Mon Mar 02, 2009 10:51 am |
I have two boards to work with sd/mmc card with different pics, board 1 has 18f2620 and board 2 18f4620, both running at 10Mhz (or even 40Mhz pll) with 3.3V. Also I have 3 sd cards: nokia micro sd 256mb, sandisk micro sd 2GB and Kingston SD 2GB.
In board 1 (with 18f2620) I've tested these sd cards and I had success in all three.
but in Board 2 (18f4620) only the micro sds worked. Kingston 2GB doesn't work at all. And in a deeper analysis I found out that Kingston sd card never leaves idle state, and the worst thing is... after sending cmd0 and then cmd1 (cmd55+acmd41) the sd cards respond with 0x01 (idle state) two or three times then the sd card just respond with 0xff. Somebody just experienced this problem too ? What could be causing that? bad pcb layout or sd connector ?
Hope someone can help.
thanks in advance.
Andre _________________ Andre |
asmallri
Joined: 12 Aug 2004 Posts: 1663 Location: Perth, Australia
| Re: SD Card Initialization problem |
Posted: Mon Mar 02, 2009 2:30 pm |
| andreluizeng wrote: | Hi,
I have two boards to work with sd/mmc card with different pics, board 1 has 18f2620 and board 2 18f4620, both running at 10Mhz (or even 40Mhz pll) with 3.3V. |
How are you getting 40MHz at 3.3 volts with these PICs?
Post a link to your SD interface schematics. _________________ Regards, Andrew
andreluizeng
Posted: Mon Mar 02, 2009 4:31 pm |
asmallri
dont worry about 40MHz, Im using only 10MHz... a part of my schematic can be viewed in this link:
http://img211.imageshack.us/img211/8601/board1.jpg
this is for board 1 with pic18f2620 the difference from another board is that I have some dipswitches between PIC´s pin and the peripherel connected on it.
I just got more 4 cards to test following by:
Vendor Type Size Result
1 - Lexar professional SD Card 1GB Success
2 - Cannon SD Card 32MB Success
3 - Sandisk MMC Card 32MB Success
4 - Kingston Micro SD 2GB Failure
I dont understand.. Im just having problems with Kingston cards =(
and the result was the same.. after a few answers (0x01) after CMD1 (or CMD55 + ACMD4) the card stop responding (0xff).
thanks in advance.
regards. _________________ Andre |
Posted: Mon Mar 02, 2009 5:43 pm |
You are switching the power to the SD card by a transistor. The minimum allowed voltage for these cards is 2.7V.
3.3V - Vce voltage of 0.6V = 2.7V
In theory this should be OK, but you have no error margin. It is a simple test to replace the transistor by a jumper.
Are you using the code as posted in http://www.ccsinfo.com/forum/viewtopic.php?t=37463 ?
Read my comments in that thread. |
andreluizeng
Posted: Mon Mar 02, 2009 6:01 pm |
I measured 3.28V on SD card... after that Im sure that the supply voltage is not the problem.
thanks
andreluizeng
Posted: Mon Mar 02, 2009 6:04 pm |
I made a little modification in this code.. the way that Im sending commands and treating the responses... but In both cases I´ve got the same problem with Kingston Cards.
Posted: Mon Mar 02, 2009 6:28 pm |
| andreluizeng wrote: | | I measured 3.28V on SD card... after that Im sure that the supply voltage is not the problem. | Did you use a scope for measuring the voltage? Average current consumption for the card will be low, but peak currents could cause voltage drops.
Thinking about it, it would be good design to add a 100nF capacitor to the low side of the transistor. |
asmallri
Posted: Mon Mar 02, 2009 7:55 pm |
I suspect your power supply switching logic is the culprit. The circuit is too close to the tolerances - its operation is dependant on HFE of the transistor. To test this theory, short out the emitter-collector.
Logically you would expect the current consumption to be higher on the higher capacity cards however the age of the respective implementation means we cannot assume that is the case.
I have tested Kingston cards without problem and if you are 100% sure your 2620 implementation works, then I would be examining the hardware implementation in greater detail. _________________ Regards, Andrew
andreluizeng
Posted: Mon Mar 02, 2009 10:24 pm |
Ok, I will make these modifications and see what will happen.
thanks again, you are helping me a lot, I will post results as soon as I can
andreluizeng
Posted: Mon Mar 02, 2009 10:47 pm |
You were right guys... the problem was in my switching logic... kingston was not hanging out on the edge, when I made the jumper on transistor and it worked. Now Ill try to fix it in a better way is possible, since this circuit is already mounted in a pcb.
thanks again for helping.
asmallri
Posted: Mon Mar 02, 2009 11:24 pm |
Try a 1K base resistor instead of 2.2K _________________ Regards, Andrew
Posted: Mon Mar 02, 2009 11:36 pm |
asmallri
it worked with 1k5, thanks a lot.
now im going to bed and try to sleep a little, 2:22 am here, and I need to wake up early to go to work... what im doing here is just for fun =)
best regards. |
