fgetc
penman
fgetc
PostPosted: Mon Mar 02, 2009 4:24 pm     Reply with quote
I am trying to use fgetc to pull bytes from a data stream at 10.4K baud.
Is there a minimum time requirement between bytes to ensure each byte is valid data.
SherpaDoug
PostPosted: Mon Mar 02, 2009 5:27 pm     Reply with quote
Using a hardware UART a Stop bit can be immediately followed by the next Start bit.
Using a software UART is actually slightly faster. Software getc() returns after the Stop bit is detected in the middle of the bit which for the usual N,8,1 settings is only 9.5 bits from the beginning of the Start bit, instead of 10 bits for the hardware UART.
If you allow a full 10 bit times per byte (Start bit, 8 data bits, Stop bit) you will be safe.
PostPosted: Mon Mar 02, 2009 5:33 pm     Reply with quote
thanks
