printf with arrays
printf with arrays
PostPosted: Sat Feb 28, 2009 7:27 pm     Reply with quote
I'm trying to use printf to print a series of array data to my LCD but it won't compile. I keep getting this error: "Printf variable count (%) does not match actual count" My compiler is PCM 4.086.
Here is my code:
// parameters
int16 pv[5];           // current temperature 0-500
lcd_init();
pv[0]=200;
pv[1]=202;
pv[2]=204;
pv[3]=206;
pv[4]=208;
printf(lcd_putc, "\f%s %s %s %s %s",   "TNK",   "HS1",   "GN1",   "HS2",    "GN2");
printf(lcd_putc, "\n%u %u %u %u %u", pv[0], pv[1], pv[2], pv[3], pv[4]);
I have also tried this with the same result:
printf(lcd_putc, "\n%u %u %u %u %u", *(pv), *(pv+1), *(pv+2), *(pv+3), *(pv+4));
Any tips on how to do this?
future_
PostPosted: Sat Feb 28, 2009 8:01 pm     Reply with quote
What I can see is that you are trying to print longs with %u, you should use %Lu.
PostPosted: Sat Feb 28, 2009 8:40 pm     Reply with quote
That fixed it. The compiler must have been trying to tell me in a roundabout way that I had the wrong number of bytes.
I stared and stared and couldn't see my mistake. I'm not used to 8 bit integers and 16 bit longs yet.
Many Thanks...
