displaying values on LCD
that guy
PostPosted: Fri Feb 27, 2009 2:46 pm     Reply with quote
I have a PIC 18f4520 that i am using with the PICDEM 2 Plus demo board, the Rohs version. I can output stand text, but now I want to output a value.
#include <18F4520.H>
#use delay(clock = 4000000)
#define LCD_POWER  PIN_D7
#include "Flex_LCD.c"
int num = 0;
   output_high(LCD_POWER);  // Turn on power to LCD
   output_low(LCD_RW);      // Set R/W pin on LCD to a low level
   lcd_init();              // Initialize the LCD
   lcd_putc('\f');
   while(true);
      lcd_putc(num);
      delay_ms(250);
      num++;
PostPosted: Fri Feb 27, 2009 2:55 pm     Reply with quote
'num', is a binary value, starting at 0, and incrementing by one each time round the loop. 'putc', outputs a _single_ character. So, your code will print every possible character from 0 to 255.
Look at 'printf', which converts values into their ASCII format for output.
printf("%d\n\r",num);
Read the manual to work out what the other characters here are doing.
PostPosted: Fri Feb 27, 2009 3:07 pm     Reply with quote
Also, please don't start a new thread every time you have a new question
about displaying characters on an LCD. You already have an existing
thread on the topic, here:
http://www.ccsinfo.com/forum/viewtopic.php?t=37985
You can add new questions to the existing thread.
PostPosted: Fri Feb 27, 2009 3:50 pm     Reply with quote
I tried the printf command but it is still not working. When I tried the printf it gave me the error STDOUT not defined (may be missing #use rs232). I know C and C++ programming so I understand what the notations are doing, I'm just new to this compiler and just need to get use to it.
#use  rs232           //Do I need this
int num = 0;
   lcd_putc('\f');
   while(true);
      delay_ms(250);
      num++;
PostPosted: Fri Feb 27, 2009 3:52 pm     Reply with quote
As I said, _read the manual_.
By default, all commands talk to STDIO. You want to talk to lcd_putc. Look at the entry for printf, and it shows how to do this.
