I use a 18f8720 at 6Mhz and the latest compiler from version 3 (3.249?)
Sofar I have a LCD and I can write and read blocks(512byte) to and from MMC card(32MB). Serial to pc(38400baud) is also set up.
I need to write small soundfiles few seconds each (mp3,wav) on the MMC card, through serial pc connection.
Do I need fat16/32?
I assume wav will be easier later on when sending data to the Futurlec.com mini mp3 from ETT?
Any links or ideas to proceed?
asmallri
Posted: Wed Feb 25, 2009 12:16 am
You do not need to use FAT16 or FAT32 unless you want to be able to remove the card and have it read by a PC. You will however have to manage your own file structures.
You might find it quicker and easier to use a FAT rather than reinvent the wheel. If you are interested check out the file systems on my site. _________________ Regards, Andrew
