from string to variables...
ferkar
PostPosted: Tue Feb 24, 2009 2:58 am     Reply with quote
hi,
I have a basic string question.
How could I extract a data from a string?
For example:
"set123f214..." this string should be separated as "set","123" and "f","214"
Any idea?
Wayne_
PostPosted: Tue Feb 24, 2009 3:29 am     Reply with quote
This all depends.
Does "set" change ?
If "set" does change is it always 3 chars ?
Is it allways 'f' ?
Is it allways 1 char ?
Are there always 3 numbers after each e.g. "001" ?
Do the values go above 255 ?
Will you ever get a number in the first set of chars ?
If it is fixed then it is very easy.
Otherwise you will need a routine to parse the string
ferkar
string!
PostPosted: Tue Feb 24, 2009 3:47 am     Reply with quote
"set" never changes
"f"never changes
the string contain numeric values "123" changes from"0000" to"9999"
the data format is always in the form of "abc" and"1234"
thanks
