4x4 Keypad Code in CCS C Compiler using PIC16F877, PortC
Nisar
PostPosted: Sun Feb 22, 2009 12:40 pm     Reply with quote
Hello every body
I'm using PIC16F877 and interfacing 4x4 Keypad with Port C.Plz any body send me its Code.I'm using CCS C Compiler.
Regards
Nisar
PostPosted: Sun Feb 22, 2009 1:00 pm     Reply with quote
Look in the CCS Code Library forum. It has links to a 4x4 keypad driver.
Nisar
4x4 Keypad have Connection with PIC16F877 at PortC
PostPosted: Fri Feb 27, 2009 12:20 am     Reply with quote
Plz any one send me C Code.
My 4x4 Keypad have Connection with PIC16F877 at PortC as following.
Colo Pin_C3
Col1 Pin_C2
Col2 Pin_C1
Col3 Pin_C0
Row0 Pin_C4
Row1 Pin_C5
Row2 Pin_C6
Row3 Pin_C7
all pins are Connected with 10K Pullup resister.
Thanks in advance
PostPosted: Fri Feb 27, 2009 12:35 am     Reply with quote
Did you look in the Code Library ? Did you try ? If you did, you would
have found this link:
http://www.ccsinfo.com/forum/viewtopic.php?t=28022&start=14
Nisar
PostPosted: Thu Mar 05, 2009 10:57 pm     Reply with quote
Thanks PCM Now 4x4 Keypad work properly
miji88
PostPosted: Wed Apr 13, 2011 3:17 am     Reply with quote
How can I program using ccs compiler for keypad 4x3?
i'm student that realy need help to learn
PostPosted: Wed Apr 13, 2011 5:28 am     Reply with quote
miji88
All you need to do is look at the program that PCMprogrammer offered above. It is well commented and easy to understand, very easy to modify to a 4 x 3 keypad.
Refer to the onscreen help(F11) that CCS supplies to read what the commands/functions/etc. are doing if you're not sure.
miji88
PostPosted: Wed Apr 13, 2011 6:27 am     Reply with quote
nice... thanks dude.. I try modified it first.
PostPosted: Wed Apr 13, 2011 1:19 pm     Reply with quote
CCS Code Library already has the 4x3 driver. You don't have to modify
the 4x4. Here's the link:
http://www.ccsinfo.com/forum/viewtopic.php?t=26333
Also, CCS has their kbd.c driver, which is for a 4x3 keypad:
c:\program files\picc\drivers\kbd.c
