using 16F877A config for FPAA
doianhve
View user's profile Send private message Yahoo Messenger ICQ Number
PostPosted: Sat Feb 21, 2009 10:00 pm     Reply with quote
hi all.
I want to make a development board for FPAA.
I use MCU Pic 16F877A and CCS compiler. But I have a problem about Configuration for FPAA. I don't know where to start. My project use Data Block for config FPAA. When board start MCU read data config from EEPROM, after sent to FPAA. But I don't know when config FPAA. Must I use pin of FPAA? How step for config FPAA? Help me if you know. Send to me hung.nguyenduc@lab3i.com
Thanks very much.
love every one !
FvM
PostPosted: Sun Feb 22, 2009 6:44 am     Reply with quote
You may want to help http://acronyms.thefreedictionary.com/FPAA by posting a new definition ...
PostPosted: Sun Feb 22, 2009 10:36 am     Reply with quote
He means this board:
http://www.anadigm.com/_doc/UM023100-K001.pdf
They have a forum and he is already posting in it:
http://www.anadigm.com/forum/forum.asp?FORUM_ID=8
FvM
PostPosted: Sun Feb 22, 2009 1:07 pm     Reply with quote
Thanks for clarifying, I even had some Anadigm datasheets, but I didn't see the question related to programmable analog chips. Actually they have a SPI like serial interface (similar to the proprietary configuration interface of many FPGA). So it's perfectly supported by a PIC and CCS built-in functions.
The first step to answer the question is literature of the Anadigm datasheet, detail problems of Anadigm configuration seem to be rather off-topic at CCS Forum.
