PIC16877A + LCD Problems
s.achilless
PostPosted: Sat Feb 21, 2009 9:18 am     Reply with quote
Hello everbody,
Can anyone help me about this code ? I am new on the pic programming.
I compile the code below and upload it into Pic16f877a but the lcd did not display anything ? where am i wrong ?
I use ex-b kit int www.expkits.com/?s=ex1-b.htm
#include <16F877A.h>
#fuses HS, NOWDT, NOPROTECT
#use delay(clock=2000000)
#include <lcd.c>
// in ldc.c, i already uncomment //#define use_portb_lcd TRUE
void main(void) {
   lcd_init();
   while (TRUE)
     lcd_gotoxy(1,1);
     lcd_putc ("\f Hello \ ");
PostPosted: Sat Feb 21, 2009 1:00 pm     Reply with quote
This is only set for 2 MHz. Almost certainly, it should be 20 MHz.
Also, add the NOLVP fuse.
s.achilless
PostPosted: Sat Feb 21, 2009 1:15 pm     Reply with quote
I set clock 20.000.000 and also fuse NOLVP but there is still no changes ? :(
PostPosted: Sat Feb 21, 2009 3:30 pm     Reply with quote
See this thread about solving LCD problems:
http://www.ccsinfo.com/forum/viewtopic.php?t=29412&start=1
