example code for DUAL EUSART using streams
Post new topic   This topic is locked: you cannot edit posts or make replies.    CCS Forum Index -> General CCS C Discussion
asmboy
PostPosted: Fri Feb 20, 2009 9:52 am     Reply with quote
about to undertake a project that requires two 38.4k RS232 channels, and i plan on using 18f8722.
some example code for uart stream channel setup would be invaluable, but a search of CCS compiler supplied doc and examples - and of old posts on this forum got nothing.
i'd be grateful for a link to any source code that clarifies the dual uart setup for streams procedure.
i think i'm for sure OK on using printf() and kdhit() - streamwise
its the pesky setup for the hardware that is unclear
PostPosted: Fri Feb 20, 2009 1:57 pm     Reply with quote
See these two threads. They have sample code for using dual UARTs
with streams:
http://www.ccsinfo.com/forum/viewtopic.php?p=95979
http://www.ccsinfo.com/forum/viewtopic.php?t=33700
asmboy
PostPosted: Fri Feb 20, 2009 9:13 pm     Reply with quote
so since i'm basically fast-polling and dealing with only short sequences ( that the fifo can accomodate ) no INTS
#use delay(clock=32000000) // defining the clock for Mr. compiler
#use rs232(baud=19200, xmit=PIN_C6,rcv=PIN_C7,ERRORS,UART1,STREAM=COMM)
#use rs232(baud=38400, xmit=PIN_G1,rcv=PIN_G2,ERRORS,UART2,STREAM=CARD)
then match the #use RS232 statements to a defined hardware UART pin set and Mr. compiler handles that too.
thats all there is to it huh ?
why do i feel that the CCS compiler is nicer and better than i deserve?
thanks for the lead PCM !!!!
Post new topic   This topic is locked: you cannot edit posts or make replies.    CCS Forum Index -> General CCS C Discussion All times are GMT - 6 Hours
