HS PLL
mshearer
HS PLL
PostPosted: Wed Feb 18, 2009 9:24 am     Reply with quote
Hi, can i just re-assure myself by asking
is
#fuses   H4               // HS/PLL
#use    delay(clock=40000000)
all that is needed to set up a 40Mhz clock off a 10MHz crystal using pllX4?
thanks,
Matthew
PostPosted: Wed Feb 18, 2009 9:37 am     Reply with quote
What chip?.
The oscillator configuration varies on different chips.
treitmey
PostPosted: Wed Feb 18, 2009 11:43 am     Reply with quote
If your having problems,.. also note that the PLL doesn't re-sync till you power off and on again.(power cycle)
mshearer
PostPosted: Thu Feb 19, 2009 3:43 am     Reply with quote
Chip is the 18F4520.
My serial comms all work fine, which i guess is a good indicator that the clock/baud are working correctly
thanks for your help
matt
