You can expand the if() statement above, so that it also sets a global flag
to TRUE. The code in main() can check this flag. If it is TRUE,
then you can send data from the buffer[] array to the PC with printf.
Also set the flag to FALSE. The flag should be initialized to FALSE
at the start of main() in the slave code.
