Weird Float and USART Problem
MicroManiac
View user's profile Send private message Send e-mail MSN Messenger
PostPosted: Tue Feb 17, 2009 8:42 am     Reply with quote
Hello, i am using PIC18F4620 and the compiler version of 4.085
and trying to execute the following code
#include <18F4620.h>
#device adc=8
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#FUSES BORV21                   //Brownout reset at 2.1V
#FUSES NOWRTD                   //Data EEPROM not write protected
#FUSES NOEBTR                   //Memory not protected from table reads
#FUSES NOCPB                    //No Boot Block code protection
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES NOWRTC                   //configuration not registers write protected
#FUSES NOWRTB                   //Boot block not write protected
#FUSES NOFCMEN                  //Fail-safe clock monitor disabled
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#FUSES NOPBADEN                 //PORTB pins are configured as digital I/O on RESET
#FUSES LPT1OSC                  //Timer1 configured for low-power operation
#FUSES MCLR                     //Master Clear pin enabled
#use delay(clock=8000000)
#use i2c(Master,Fast=400000,sda=PIN_D1,scl=PIN_D0, FORCE_SW)
#include "C:\Documents and Settings\Bernard Kazour\My Documents\Course Finder\Java Website\C code\main.h"
#include <stdlib.h>
#include <input.c>
#include <math.h>
void ComputeFormCD();
void crsdist();
//int signlat1,signlat2,signlon1,signlon2,dc
float degLat1,degLat2,degLon1=0,degLon2=0;
float lat1,lat2,lon1,lon2;
float d,crs12,crs21;
float argacos;
float a,invf;
   setup_oscillator(OSC_8MHZ|OSC_TIMER1|OSC_IDLE_MODE|OSC_31250|OSC_PLL_OFF);
   delay_cycles(4);
   setup_psp(PSP_DISABLED);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_vref(FALSE);
//Setup_Oscillator parameter not selected from Intr Oscillator Config tab
   // TODO: USER CODE!!
  // while (1)
      degLat1 = 31.3;
      printf ("%f",degLat1);
      printf ("\n\r");
      degLon1=12.26;
      printf ("%f",deglon1);
      printf ("\n\r");
      degLat2=21.4225;
      degLon2=39.8261;
      ComputeFormCD()
      crsdist();
      crs12 =crs12*(180/PI);
      printf ("The course from 1 to 2 is: %f",crs12);
   lat1=degLat1*PI/180.0;
   printf("Lat1: %f",lat1);
   printf ("\n\r");
   lat2=degLat2*(PI/180.0);
   printf("Lat2: %f",lat2);
   printf ("\n\r");
   lon1=degLon1*(PI/180.0);
   printf("Lon1: %f",lon1);
   printf ("\n\r");
   lon2=degLon2*(PI/180.0);
   printf("Lon2: %f",lon2);
   printf ("\n\r");
void crsdist() // radian args
   /* compute course and distance (spherical) */
//!   float a1;
//!   float a2;
//!   float b1;
//!   float b2;
//!   float b3;
//!   a1=sin(lat1);
//!   a2=sin(lat2);
//!   b1=cos(lat1);
//!   b2=cos(lat2);
//!   b3=cos(lon1-lon2);
   d=acos(sin(lat1)*sin(lat2)+cos(lat1)*cos(lat2)*cos(lon1-lon2));
   printf("d: %f",d);
   printf ("\n\r");
When I try to execute it like this, all the printing on the USART are
successful, but the "d" calculation is always returning 0.
But when I remove the comments of the following lines:
//!   float a1;
//!   float a2;
//!   float b1;
//!   float b2;
//!   float b3;
//!   a1=sin(lat1);
//!   a2=sin(lat2);
//!   b1=cos(lat1);
//!   b2=cos(lat2);
These lines are used to divide the calculation of the "d" variable" because I thought that this calculation is failing because it is done directly at once, all the printing are returning 0.
Does anyone have an idea why this is happening, and how can solve this problem?
"Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction."
Albert Einstein
PostPosted: Tue Feb 17, 2009 10:50 pm     Reply with quote
I get the following results in MPLAB simulator. Is your complaint
about the last line, shown in bold ?
31.30
12.26
Lat1: 0.54
Lat2: 0.37
Lon1: 0.21
Lon2: 0.69
d: 0.46
The course from 1 to 2 is: 0.0
It's computed and displayed by these lines:
But 'crs12' is never initialized anywhere in your program.
It happens to be 0 upon power-up (at least in the simulator).
That's why the result is always 0.
MicroManiac
PostPosted: Wed Feb 18, 2009 1:14 am     Reply with quote
well, when i am using the USART, the "d" is always returning 0.
i am surprised that it is returning a result in the MPLAB simulator. the other values are the same.
i didn't post my whole code, the calculation of the "crs12" is based on "d".
i thought there was a problem in "d" and there is no need to post everything.
Why do you think when i send "d" over the USART it is returning 0?
Albert Einstein
PostPosted: Wed Feb 18, 2009 1:20 am     Reply with quote
If possible, post a short test program that demonstrates this problem.
(The program should be much shorter than the program you already
posted).
Also, post the name of the terminal program that runs on your PC.
PostPosted: Wed Feb 18, 2009 1:31 am     Reply with quote
I only see, that crs12 is never set to a value in your code, so it can be expected zero. Is this the problem?
MicroManiac
PostPosted: Thu Feb 19, 2009 1:26 am     Reply with quote
Well that is not the problem
i created a new project and recompiled everything and it worked smoothly
dunno what was happening before
thank you all for your help
Albert Einstein
PostPosted: Thu Feb 19, 2009 3:46 am     Reply with quote
In other words, your previously posted code has been meaningless or misleading.
MicroManiac
PostPosted: Fri Feb 20, 2009 3:18 am     Reply with quote
Actually Not,
i've taken that exact code, recompiled it in a new project and it worked fine.
My problem was in the "d" variable not the "crs12" variable, but it was solved now and i dunno what was the problem
Albert Einstein
